New Member and Lost
Old Aug 12, 2013 | 02:11 PM
mlbirk's Avatar
mlbirk
New Member and Lost
Hi all,
I'm not sure where to post or find info on my truck as it isn't really a truck per se. I bought a 1994 Motor Home that is built on a Ford E-350 chasis with a 7.5 liter gas engine.
Is there a seperate forum for the E series or would I post here?
Old Aug 12, 2013 | 02:33 PM
White 97 xlt's Avatar
White 97 xlt
First off Welcome to FTE.....
There is actually an E series forum Located here:: 1968-2013 Full Size Vans - Ford Truck Enthusiasts Forums
But odds are you will get as many or more people seeing your post here, we can most likely answer 99.9% of you questions here, after all the E series is just a different shaped Ford truck...
Old Aug 12, 2013 | 02:47 PM
Encho's Avatar
Encho
The Southernmost Mod
Yes, we won't tell you to F-you since you don't own a F-series, hehehe the parts are mostly the same, except chassis and bodies.
Old Aug 12, 2013 | 02:55 PM
White 97 xlt
Who says we won't? I've come pretty close a few times, but it was not for having an E series truck!!!!
Old Aug 12, 2013 | 03:53 PM
mlbirk's Avatar
mlbirk
Thank you all fo the warm wlecome. Since you've offered, I am looking for a solution to a problem that just cropped up.
With the engine running, all gagues read normally however I hear a metalic thump ot "tink" that causes the voltmeter to drop and then come right back up. To me it sounds like a relay or solenoid that keeps disengaging causing the voltmeter to fluctuate. It happens on a fairly consistent 20 -30 second interval. I am thinking that it could be a bad voltage regulator which I understand Ford still mounted outside of the alternator.
If anyone else has any thoughts, they would be greatly appreciated.
Old Aug 12, 2013 | 04:15 PM
White 97 xlt
Yes, the voltage regulator is in the alternator, and is all electronic, so no relays there..... How ever the later trucks seem to be full of other relays....
I have one thought, a friend had a motor home several years ago that did almost the same thing, his turned out to be the charging relay for the "house" battery.. The battery was shot and it would load up and try to charge but the load would kick it out, the best I remember the battery had an internal short.. Replaced the battery and all was good from then on...
Have you tried to locate the clicking relay? If you could find it you might be able to trace the wiring from it to see what is messed up.
BigF350
Large Truck
104
Aug 23, 2024 10:00 AM
Ajohns1141
43
Mar 3, 2014 04:25 AM
fabmandelux
13
Nov 17, 2011 08:45 PM
lifted04xlt
Jun 8, 2008 05:53 PM
dono
1983 - 2012 Ranger & B-Series
Jul 31, 2003 09:12 AM
