Motor Rebuild
Need your experience and expertise on this matter. As I mentioned earlier, just bought my dream 49 Ford however, the more I look at it, the more I notice things that have to be repaired. In fact, this is becoming a bit overwhelming. Was reminded not to try and do it all at once so I pose this question to you.
In desperate need of a motor rebuild and new transmission. Currently have 350 trans but I want something with an OD a 7004R would be my preferred. Also looking for shop that is reasonable and do good work to rebuild my 350. I am in the San Antonio area, any help/suggestions would be greatly appreciated.
How much in the budget? Is where I would start. and what you want out of it.
I wanted horsepower so I couldn't buy one for what I have in mine.
I wanted a torque motor. It is a clone for the GMC 383HT crate motor so I bought a stroker crank. We dyno'd it at his shop. It came out at just over GM advertised specs. It is a torque motor so the HP was only 345 (at 4600rpm) but torque was over 400 for a long range peaking at 440. He did not charge me for the dyno runs since I did all of the setup and breakdown on his dyno.
When you say "rebuild my 350" are you referring to TH350 or SBC 350. It's easy to make some SBC 350s run 300 HP or better. First, I'd do a sanity check. Why do you feel that it needs a rebuild? Does it burn oil? If so, is it valve guides, rings, or both? Is performance lacking? Is it over carburated and/or have way too big of an intake for the design? Have you done a thorough tuneup?
Give us some better information and perhaps we can be of more help at saving you money while getting you going.
1) Yes, I believe I can swap over my timing cover and use the new CCW (correct for my truck) water pump to get past these possible issues
2) They list this as up to 1997 (has a “seasoned roller rocker block”) but not compatible with EFI trucks. I believe that is because of the timing cover issue and a cam that would be hard for the EEC-IV to work with - unless I go with an aftermarket EEC-IV tuning solution.
3) I plan to swap in the Comp 35-349-8 cam and set it up with the OEM rockers and pushrods, keeping the OEM cast iron heads to start with as I am going to be looking at the timing chain anyway when I swap over the timing cover.
4) If I want more power, the stock cast iron heads at 62cc and a CR of 9.5:1 can come out in favor of the Flotek Al heads at 58cc (a bit more CR).
