trying to find info
Old Aug 10, 2013 | 05:59 PM
71fordlover5516's Avatar
71fordlover5516
trying to find info
Ive had a 71 Ford F100 Sport custom for some time now, but i need to replace a flex plate, but ive run into a problem. My truck has a 400 in it, but i cant find any info on a 71 f100 with that engine. The biggest i can find is a 390, but im not sure if they're compatible. To my understanding the 400 was introduced in 71, but im not sure if it was built with it or someone put it in later.
Mainly i just want to know the cost of a flex plate, if a 390 will work with a 400, how long can it take to replace, and is there anything specific I need to know?
Old Aug 10, 2013 | 06:16 PM
jowilker's Avatar
jowilker
71fordlover5516 Welcome to FTE & The Bumbside Forum.
If your truck has the 351-400 in it, that engine was introduced in 77. Check that year to see if you get a match. There may have been other 400 engines from Ford, but the truck was 77.
John
Old Aug 10, 2013 | 06:36 PM
arctic y block's Avatar
arctic y block
John is right on. In 71 you should have a 360 FE engine. Same block as a 352 or 390 or several bigger. Check out what ya got. look for a number cast in that is 352. That will tell us it is an FE. But post up a pic of it if ya can. How many valve cover bolts does it have on one side? It could also be a 302. But if it is a 351M/400 than it has been swapped in and the engine mounts have been modifyed and should be easy to see the cobbled welding.
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Aug 15, 2013 | 06:03 PM
71fordlover5516
Ok. Thanks for all the help, and I'll try to get the pics up. Im currently in the process of moving so it might take a couple of days to do so.
Old Aug 16, 2013 | 05:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 71fordlover5516
I've had a 71 F100 Sport Custom for some time now, but i need to replace a flex plate, but I've run into a problem.
My truck has a 400 in it, but I can't find any info on a 71 F100 with that engine.
Not surprising, since the 400 wasn't available in F100/350's until 1977.
Welcome to FTE
400 (and 351C/351M) have 8 valve cover bolts per side.
1968/72 F100/350 available engines, 4th digit of the VIN is the engine code: A = 240 I-6 / B = 300 I-6 / G = 302 2V (1969/72 F100 only) / H = 390 2V / Y = 360 2V
D1AZ-6375-A .. 351M/400 Flywheel (Flexplate) / Obsolete
1971/79 FoMoCo Passenger Cars 400/C6 - 1975/79 FoMoCo Passenger Cars 351M/C6 // C6 only A/T available: 1977/79 F100/350 - 1978/82 Bronco - 1980/82 F150/350 & Econoline.
Make sure your truck has a C6. If the 400 was swapped from a car, it could have a C6 (17 trans pan bolts), or a C4 (11 trans pan bolts), or an FMX (14 trans pan bolts).
BryanMichael1989
Apr 27, 2014 01:46 PM
hanksy
Aug 17, 2013 08:07 PM
PRY046
25
Jul 21, 2013 11:27 PM
cbablair
Mar 18, 2013 11:30 AM
thomc
Nov 2, 2012 03:05 PM
