1996 transmission problem's E40D
Old Aug 8, 2013 | 12:09 AM
hawk1959's Avatar
hawk1959
RATROD58
My tranny shifts hard , and the OD light is blinking on and off , and the Dome lights don't go out when the door is shut , and when the speedometer is hooked up the tranny will slip after second gear or third gear ,but when i unplug the speedometer the tranny stops slipping
Old Aug 8, 2013 | 07:51 AM
subford's Avatar
subford
It is normal for the transmission to shifts hard and the OD light to blink on and off if the speedometer is unplugged.
With the speedometer unplugged the oil pressure will go to maximum.
You may also have worn clutch plates and seals or low oil pressure in the transmission. You need to hook a gauge to transmission and see what the pressures are with the speedometer hooked up.
mudman1
17
Mar 13, 2018 06:14 PM
gpacster
15
Aug 16, 2015 11:01 AM
Pete Roberts
Feb 23, 2011 02:13 PM
fxdwg
Aug 30, 2005 04:01 PM
