ScanGauge Recommendations
Old Aug 7, 2013 | 07:36 PM
johnsonjf's Avatar
johnsonjf
Good Evening,
I am looking for a Scangauge to use on my upcoming Excursion. There are several different models and I would appreciate input about which offers the better options. Explanations would also be appreciated.
Thank you,
Jeff
Old Aug 7, 2013 | 10:01 PM
VQT's Avatar
VQT
Scanguage II
Old Aug 7, 2013 | 10:15 PM
johnsonjf's Avatar
johnsonjf
Can you tell me why over other products like ScangaugeE or Dashboss?
Thanks,
Jeff
Old Aug 7, 2013 | 10:48 PM
william_04_x's Avatar
william_04_x
Since you specifically inquired about Scangauge products, I'm pretty sure that's why VQT recommended the ScanGauge II by Linear Logic. As far as to why that is preferred(over the SGE), the main reason is the ability to program the X Gauges. The X Gauge feature lets you input codes(as they are developed/discovered) to the unit for specific performance/operating information. This allows the user access to a greater amount of information than is available from typical digital gauges with predetermined/generic data sets.
Have you decided which engine you desire in the Excursion you intend to purchase?
Old Aug 7, 2013 | 10:50 PM
Romanova's Avatar
Romanova
SG2... ease of use is great!
Old Aug 8, 2013 | 12:47 AM
robert_l_ross's Avatar
robert_l_ross
I had the ScanGauge on my Expedition and liked it...tried the UltraGauge on my Excursion and I'm liking it even more. It has the ability to display 6 or more values at a time (I think the max is 8 at a time) in something like 6 different pages - all programmable...so 48 different gauges. Downside is it doesn't have the different color option like the ScanGauge.
Old Aug 8, 2013 | 06:07 AM
johnsonjf's Avatar
johnsonjf
Sorry, I should have mentioned engine type in my original post. I will be using the 6.0 PS.
Jeff
Old Aug 8, 2013 | 04:40 PM
VQT's Avatar
VQT
Jeff
Go to this link below
https://www.ford-trucks.com/forums/1...uto-parts.html
Old Aug 8, 2013 | 07:33 PM
fishintheobx's Avatar
fishintheobx
I'll go a little off-topic here for another solution. I saw a guy that ran the $5 Torque App on his Android device and a $25 bluetooth ODB adapter he got on eBay. The info he was pulling off his 6.0 ECM was insane. I have the SCT Livewire TS for my tuner and monitor, and he was pulling info I didn't even have the options for. The data logging alone blew my mind when he could pull up a day and temperature for where he was on a map, and how the truck performed. Very impressed.
Torque — OBD2 Performance and Diagnostics for your Vehicle
Old Aug 8, 2013 | 08:45 PM
william_04_x
I have a SGII, and Torque Pro. As cool as torque is, the SGII is much more convenient, as it's always mounted and doing it's thing. Docking a phone all the time can be a bit of a PITA. I've considered mounting a spare phone I have for a semi permanent Torque display/media player, but that could lead to a break-in, and I don't want to invite that.
Old Aug 11, 2013 | 06:02 PM
CLINT-THE-GREAT's Avatar
CLINT-THE-GREAT
Posting Legend
Why is it that pretty much no one has an UltraGauge? I think the SG2 looks like its from the 90s. UG looks cleaner and more crisp? Does the UG not do some things the SG2 does?
-The Great
Old Aug 11, 2013 | 06:13 PM
robert_l_ross
I've got one...prefer it over the ScanGauge. I do wish they'd update the design to allow for different color display settings, but even without that - the product is (in my opinion) superior to the ScanGauge.
I know some will chime in that the ScanGauge lets you add gauges, but for a gasser at least, the UltraGauge comes with all you need.
Old Aug 11, 2013 | 07:00 PM
CLINT-THE-GREAT
Posting Legend
I already have actual EGT, TRans temp, and Boost gauges. I was really just looking for a water and Oil temp so I don't idle the truck all the time, but I just think the SG2 is fugly. Does the UG have a fuel pressure gauge on it?
-The Great
Old Aug 11, 2013 | 09:47 PM
william_04_x
In addition to the basics, SGII will read three parameters from the FICM, cylinder misfire counts, cam/crank sync, EGR valve duty cycle, turbo solenoid duty cycle, IPR % and/or voltage, ICP % and or volts, and at least another handful of important things that others in the category won't read, and I can't remember now.
For a 6.0l, the SGII is one of the most comprehensive OBDII readers you'll find. New codes are still being created to read even more available data from the PCM. A lot of us 6.0l owners have written to Linear Logic and requested they develop code for certain PID's, and they've come through. I've had one on my 6.0l since 2005, and would purchase another if it failed. Except for Ford IDS, or AutoEnginuity(both laptop based), nothing else will give you as much data from your 6.0l. Torque Pro is pretty darn close.
Royson12
Aug 5, 2014 03:23 PM
Don Rocco
Oct 19, 2012 06:35 PM
pin8246
21
Sep 4, 2012 11:32 AM
SunBum
17
Aug 2, 2011 06:36 PM
06F250XLTFX4
Feb 12, 2006 03:22 PM
