2150A carburetor
1. What is the actual difference between a 2150 and 2150A carb?
2. What does Feedback mean?
The carb I have has most of the lines plugged. The only connections on the carb are the throttle linkage, wire going to the choke adjustment and the fuel line.
It was this way when I got it. Currently it runs cold. I have to pump the gas 3 or 4 times before it will start and then it needs to warm up for 5 minutes or so or it will die when I take off.
It also has not getup and go when I press the gas. I dont expect it to chirp the tires but it lags a lot.
The factory tach does not work either. Not sure it is related.
Full disclosure: Thinking the fuel filter needed to be changed I changed it and while tightening it, I cracked the bowl. I was able to seal the crack temporarily but I would like to replace the carb.
3. Could I get a 2150 and swap it out?
4. If not what will I need to do to replace it with a different type of carb?
5. What type of carb should I get?
Any info will be greatly appreciated.
rick
Do you have any type of inspections? How close do they look? If it where mine, I would save up and find a used cast iron 4bbl intake, or buy a new aluminum one. I would then buy a small 600cfm holley or a small edelbrock 4bbl and install that, along with a new distributor. You can get a duraspark II unit and a ignition module for it, or get some other ignition system that you would like to run, that would have the old type mechanical advance and vacuum advance units on it to control the timing. You will be surprised how much this carb and distributor team will wake this engine up.
The feedback carb had a passageway with a solenoid mounted in it. The solenoid when activated would add more fuel to the engine. The computer would look at the oxygen sensor, and would cycle the solenoid more or less to control the fuel going to the engine. It just tweaked the fuel delivery, as you have found out it will still run with it disconnected, just not very well.
1. A 2150A is the feedback version of a 2150. An ordinary 2150 has no computer related electronics.
2. A feedback carb gives electronic 'feedback' to the truck's computer from several sensors, along with an O2 sensor in the exhaust; the computer then fine-tunes the mix accordingly, via an air-bleed solenoid on the back of the carb.
The feedback 2150A still has conventional jets - the air bleed unit just gives constant fine tuning adjustments.
Disabled like yours, it will run at the rich end of it's range - but this isn't extremely rich; mine was the same way for a while, but the plugs were still not black.
3. Yes it will bolt straight on, but as Dave (Franklin2) said, the distributor & module also need to be changed to Duraspark II.
When I bought my truck a previous owner had already done the ignition swap from Duraspark III, but had left the feedback carb on for inspections in California.
I found a non-feedback 2150 & recently re-kitted it, then tossed the original 2150A, along with the computer & emissions gear (3x large boxes of stuff!).
There's a huge number of differently calibrated 2150's, so you need to get one that's at least an approximate match to your engine.
On the drivers side of the float bowls are some numbers, cast inside a circle - e.g. 1.08, 1.21 etc......this is the carb venturii diameter, & needs to be matched to your engine size. There are also other differences according to year & vehicle etc.
With an auto trans, you will want a carb with the kickdown lever on the throttle shaft.
Your cold-start problems are probably just from the choke needing to be set up again, assuming the normal adjustments (float level etc) are all OK. The non-feedback 2150 has the same basic choke as you have now.
Like what carb and distributor I will need to get?
There are so many choices.
Rick
The throttle cable, fuel line, air cleaner, kick-down linkage etc, will all swap from your carb straight onto a 2150 (it needs to be for an auto trans vehicle), & the stud pattern is the same.
The venturii size (numbers on the drivers side of the float bowl) for a 351 would be 1.21". If you find a carb with it's ID tag still on, you can go to a carb site & use the tag to get a kit for it e.g. -
Chicago Carburetor
Motorcraft 2150 Carburetor Parts
Someone else will know, better than me, regarding the distributor/module/harnesses etc.
I would just like to swap out the carb without having to do the ignition and distributor change out.
I have found a couple of places where I can get a carb that will swap out.
Carburetor Lookup
The guy at National said it should work.
Rick
I'm not taking anything away from Ken, as he knows far more about those carbs than I do. But, w/o the right distributor the engine's timing is locked at something like 10 degrees BTDC instead of changing with the engine's needs up to something like 34 degrees BTDC. That is a tremendous change, and without it no carb is going to make the engine run even remotely correctly.
So, you need to determine what type of distributor you have in the thing.
Pictures would be marvelous.
If the system you currently have is Duraspark III (having no vacuum advance unit on the base of the distributor), it will need to be changed to either Duraspark II, or a stand-alone aftermarket unit.
The connection is that feedback 2150A's were installed on engines with Duraspark III distributors.....both being computer controlled, & operating together as a system.
But Duraspark II distributors, & non-feedback 2150 carbs, operate independently of each other (except for a vacuum source) in vehicles with no computer.
