Greasing everything
Old Aug 7, 2013 | 02:17 PM
aidandj's Avatar
aidandj
Greasing everything
Hey guys,
I know that I need to grease a lot of the joints on my truck, but I'm not sure exactly which ones and how to do it. I've got a grease gun, but my only experience in this sort of thing is greasing my tractor back in my farmboy days, and all i did was wipe some into the steering joints. Any instructions would be great.
ADJ
Old Aug 7, 2013 | 03:54 PM
CougarJohn's Avatar
CougarJohn
Crawl under with a rag and and your grease gun. Wipe off all the nipples that you see and shoot them. And check the drive shaft. There may be grease fittings there also.
Old Aug 7, 2013 | 04:54 PM
jowilker's Avatar
jowilker
ADJ, 2x on CougarJohn, get under it and grease it zackly as you did the tractor. One full pump on each zerk should do it, unless it has been a couple years or more since it was last greased.
John
Old Aug 7, 2013 | 05:00 PM
aidandj's Avatar
aidandj
John
Are there a lot of places with grease fittings? Or should I just work it in the side.
Old Aug 7, 2013 | 05:38 PM
HIO Silver's Avatar
HIO Silver
Pump grease into all the zerk fittings you can find until the old grease is displaced. Wipe off all excess because it will simply catch/trap dirt and grit and look like hell.... Tie rods, U-joints, and ball joints/kingpins.
If a manual trans, there may be a zerk on the Z-bar and if it doesn't have one, then drill and tap for one. It beats removing the dang thing to pack it full of grease.
If equipped with power brakes, there is a zerk fitting on the booster bracket crank. It's kinda hard to see but there is one.
Old Aug 8, 2013 | 04:55 AM
jowilker's Avatar
jowilker
ADJ, Most will be on the front axle area, 6-8, some on the drive shaft.
Just get under it and find them, give it a good inspection. Take it to a local service station/garage, ask the owner to help and show you where the fittings are. I can't imagine going to one in the morning and chatting with him about what you want that he would charge you more than $10.00.
John
Old Aug 8, 2013 | 11:17 PM
aidandj's Avatar
aidandj
Found 4 on the steering, still searching for more on the driveshaft. Would the service manual have a lubrication section?
Old Aug 8, 2013 | 11:34 PM
aidandj's Avatar
aidandj
Ignore that last post, I found the ones on the drivetrain.
2 questions.
1. How do I get to the ones on some of the U-joints, are there smaller adapters for the grease gun?
2. Are there zerks on the U-joins where the wheel meets the axle?
ADJ
Old Aug 9, 2013 | 04:19 AM
jowilker's Avatar
jowilker
You may have to jack up the rear and rotate the wheels until the zerks present themselves for better attachment.
Like the ol tractor look for parts that move, run your fingers across the areas you can find them.
John
Old Aug 9, 2013 | 12:56 PM
JEFFFAFA's Avatar
JEFFFAFA
ADJ
1. Yes there is a pecil tip adaptor so you can reach the zerks in the u-joints.
2. The Ford u-joints in the front 4x4 axles never had zerks. Aftermarket joints maybe. Jack the front end up so you can spin the axles and look for zerks there.
Old Aug 9, 2013 | 01:10 PM
aidandj's Avatar
aidandj
Thanks! That's what I was looking for.
Old Aug 10, 2013 | 05:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Do not expect to find zerk fittings because in 1963, FoMoCo introduced "Lifetime Lubrication." Installed rubber plugs in the holes where zerk fittings threaded in.
Most lube men threw away the plugs, installed zerk fittings, but later on, FoMoCo sold replacement parts without holes.
One maddening example: Very few FoMoCo 'service part replacement' u-joints sold after the mid 1970's have a place for zerk fittings.
The Ford u-joints in the 4x4 axles never had zerks.
Uh, I hate to 'pull rank' on a fellow parts guy, but...
1966/72 F100/250 4WD front driveshaft could use 2-B6TZ-4635-A 1310 u-joint [12] or (1) of these and 1-C5TZ-4635-F 1310/1330 u-joint [27] or 2-C5TZ-4635-F (Spicer: 210392-X).
Depending on when they were sold, could have 87901-S zerk fittings, or rubber plugs, or could have no place for either.
F100/250 4WD pics from '64/72 catalog. Notice there's also these same zerk fittings in the 4841 slip yokes.
Old Aug 10, 2013 | 07:14 AM
1972RedNeck's Avatar
1972RedNeck
I think he's talking about the front axle shaft u joints.
Old Aug 10, 2013 | 07:29 AM
NumberDummy
Not so, Jeff's a parts guy at a Ford Dealer, so he would know that U-joints that are located inside the axle housing obviously don't have zerk fittings.
Do you see a zerk fitting on the 3249 u-joint?
Old Aug 11, 2013 | 07:54 AM
Tony65's Avatar
Tony65
Z-Bar?
This one is new to me. I've got a 68, F-100, 360, 3-speed. I'm thinking the Z-Bar is the support bracket in the rear drive shaft. I've been ioling it periodically,I didn't know it had to be packed with grease or that you could tap in a zerk...How and where do you drill and tap it in.
