fuel issue
Old Aug 7, 2013 | 09:53 PM
crazyolbob's Avatar
crazyolbob
Originally Posted by stainlessstroker95
How are you checking fuel pressure?
hooked up gauge at schrader valve port
Old Aug 8, 2013 | 06:33 PM
crazyolbob's Avatar
crazyolbob
I'm grasping at straws now, anybody have any other ideas as to what might be causing these symptoms ?
Old Aug 8, 2013 | 06:46 PM
JWC 3's Avatar
JWC 3
any codes ? You messed with the vc connections , it ran better , Are you sure that is not your problem ?
Old Aug 8, 2013 | 10:27 PM
crazyolbob's Avatar
crazyolbob
No codes and it seem to run better but after testing connections and injectors and all have checked good I think it must have been wishful thinking..
Old Aug 8, 2013 | 11:37 PM
fordman67's Avatar
fordman67
110 lbs? And it hasn't blown anything up yet? Has the regulator been shimmed?
Do you have a diagnostic tool like scanner etc. .?
Old Aug 9, 2013 | 05:35 AM
crazyolbob's Avatar
crazyolbob
surprisingly no, nothing has blown up and I don't know if it has been shimmed. Not familiar with the workings of the regulator so don't know what I'm looking for. All I have now is a code reader but have just ordered a scanner and should be here by monday
Old Aug 10, 2013 | 05:13 PM
crazyolbob's Avatar
crazyolbob
Problem solved... blown lower o-ring on injector which looked to be caused by a loose hold down bolt on the injector which allowed compression to back feed into the fuel system causing my fluctuating fuel pressure.... Thanks for everyone's input
Old Aug 10, 2013 | 08:48 PM
JWC 3's Avatar
JWC 3
That makes no sense ! Set it straight , and stay off the crazy weed !
Old Aug 10, 2013 | 08:52 PM
JWC 3's Avatar
JWC 3
Back up ... Sorry . I was thinking about another post .. gasser ... Sorry !
Old Aug 10, 2013 | 08:54 PM
JWC 3's Avatar
JWC 3
Guess I have had too many ! No smoke though ! Haven't done that since the 80's ! Sorry for the bad input !
Old Aug 11, 2013 | 12:04 AM
crazyolbob's Avatar
crazyolbob
You had me wonderin what ya was talking about LOL
JSpivey779
May 4, 2018 02:02 AM
nico963
6.7L Power Stroke Diesel
Jul 25, 2015 08:02 AM
crazyolbob
Aug 6, 2013 06:24 AM
bulletpruf
Aug 12, 2012 01:31 PM
f3501999
22
Jul 31, 2010 02:40 PM
