Sponsored by: Real Truck
Frontend Alignment--How To
Old Aug 5, 2013 | 07:06 AM
bmfrocky's Avatar
bmfrocky
2002, F-450, 2wd, drw---new tires, shocks and brake pads in last 4k miles, ball joints appear tight, tire pressure equal. On the straightaway--steering wheel at 11'oclock, and drifts to the right, no pull with braking.
Adjustment sleeves on the upper tie rod (from the gear box to the right wheel) lower tie rod (from the right side to the left wheel). Which adjustment sleeve acts on which wheel? Extending the sleeve does what? and retracting the sleeve does what? Loosen the sleeve clamps and turn the sleeve with a pipe wrench? Would measure on front and back of front tires while they are off the ground.
Thanks
Old Aug 5, 2013 | 08:29 AM
artguys's Avatar
artguys
First take it to someone who can do a toe check only...know where your at first before you start thinking about adjustments. As far as taking measurements off the tires it has to be done with the full weight of the truck on the ground, not with the wheels/tires off the ground.
Old Aug 7, 2013 | 08:15 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
With the wheel that far off, I'd get the alignment checked by a shop - you can't do it yourself with any accuracy unless you want to play around with it a lot
Midnightride42
1997 - 2003 F150
Jun 9, 2012 12:16 AM
86F150302
Jun 23, 2010 07:25 PM
qkpicker
Apr 14, 2009 12:13 PM
Supercab
Mar 14, 2009 04:22 PM
seymour
Jun 11, 2002 10:58 AM
