Gas tank replace cheats?
Old Aug 3, 2013 | 09:07 AM
odokevin's Avatar
odokevin
hey all, I have a 92 F150 dual tank, my rear tank leaks so I got a new one and new straps got all set up and realized my floor jack is broke, I dont really have the cash to go buy a new one, any ideas how to drop the tank without a jack? I have a ratchet strap from an old big rig, might be able to rig that up to lower it slowly, just to disconnect everything, but also need to hoist the new one up, hold it mid air to attach everything. any ideas would be great, thanks
Old Aug 3, 2013 | 09:59 AM
rla2005's Avatar
rla2005
I used two 1" inch ratchet straps when I changed the rear tank on my old 1992 F350 a few years ago. Worked like a charm, no jack required.
Old Aug 3, 2013 | 10:10 AM
odokevin's Avatar
odokevin
Ive got a bunch of one inch straps laying around, where did you hook them? I've stared at it a few times I can't see a good place with enough clearance. but thanks ALOT, that's just the kind of answer I was looking for.
Old Aug 3, 2013 | 10:25 AM
rla2005's Avatar
rla2005
I attached one end to the crossmember in front of the tank, The other end I attached to the hitch I had installed. It was a tight fit, but it worked out just fine. It helped the rear tank was almost completely empty.
Old Aug 3, 2013 | 10:34 AM
bashby's Avatar
bashby
If the tank is empty it is easy enough to handle without a jack.
Old Aug 3, 2013 | 12:38 PM
Conanski's Avatar
Conanski
+1... siphon the gas out first and it's easy to handle.
Old Aug 3, 2013 | 05:42 PM
kermmydog's Avatar
kermmydog
Come on guys it must weigh 25# empty. That hurts if it hits you in the head. That is part of my problems too many things dropped on my head. But the rear tanks are wedged in there pretty good.
Craig
Old Aug 3, 2013 | 05:55 PM
bashby's Avatar
bashby
Cut a 2x4 or something the right length so it is tight when jammed between the old tank and the ground, then when you get the new one where you want it, you can stick the prop under it to hold it while you put the straps on.
Old Aug 7, 2013 | 08:14 AM
odokevin's Avatar
odokevin
Thanks to everyone for the great tips. this truck wasnt taken care of with its past owner, best I can figure it was a farm truck, so nothing ever goes easy with it, now I have the tank suspended with the ratchet straps but I cant get the fuel lines to disconnect, I bought the disconnect tool a while back and changed my fuel filter, but having a bit of trouble with it now. thoughts?
Old Aug 7, 2013 | 08:31 AM
Pellas's Avatar
Pellas
An empty tank doesn't weigh much, i took mine out half full by hand, used a freind to do all the conectors and hoses while i lifted it out. 5 minute job.
Old Aug 7, 2013 | 09:04 AM
rla2005's Avatar
rla2005
Spray some lube into the fuel line connector. Use a small screwdriver to pop out any large chunks. Spray again, then wait. I ended up buying a cheap set of plastic fuel line disconnect collars. The fancy $$ metal set I had was not working for me. Go figure.....
Did I mention spray lube into the connector?
Old Aug 7, 2013 | 09:38 AM
dixie460's Avatar
dixie460
It helps if you push the connector halves towards each other while pushing the tool into it. I had a set of plastic tools... used them once and broke one of them. Got the metal ones, used them twice so far, both times worked great once you get the dirt out of the connectors so the tool can seat.
Just keep at it, it'll come apart eventually (if you're using the right diameter disconnect tool).
anthonym92
Feb 19, 2018 12:25 PM
1991fseries
1997 - 2003 F150
Dec 10, 2009 09:09 PM
84 f250 6.9
20
Oct 18, 2009 12:54 PM
So-Cal Sancho
Apr 2, 2009 09:04 PM
big steve
Dec 21, 2006 01:52 AM
