Shimming the fpr will not help with high EGTs. You need more air for a more complete fuel burn. How are the temps if you pull in a lower gear, keeping the revs higher?
Water temp was 210 to 220 my is a 410 if I ran 55 to
60 temp was 210 over it would climb I am going to
put a new radiator and a fan out of a 6.0 what do ya
think
think
I was talking about the EGT, not the coolant temps, sorry I wasn't clear on that. Usually if you use a lower gear and keep the RPMs up it will help to lower the EGT.
So I replaced my turbo and also deleated my epvb also turned my pedestal into a non epv took a cutting disk to the thing and then welded the oil holes up on it forgot to take a picture before I reinstalled
Hey 427 fordman I see u put on a 6.0 fan I am put one now
is anything I need to do or is it put it on .Also I made a post
about short a lomg thermosts what would happen if u had
short were the long should be
