89 351W stalling
Old Aug 1, 2013 | 02:12 PM
kevin206's Avatar
kevin206
89 351W stalling
I have a 89 F250 351W FI 5 speed with a stalling problem. With the truck fully warm I can drive down the road, under a load and not coasting, I let off the throttle and push in the clutch, the RPM drops to the point of stalling. This is most noticeable, and most problematic, when slowing down to make a right turn.
It's not really a new problem, but it's getting aggravating...and dangerous. I've pulled the IAC twice and cleaned it and the passageway very good, even though it looked clean anyway. The check engine light isn't on and it's not shown any codes when I've pulled them. A known issue is that the metal tube from the manifold to the EGR is broken.
Any ideas or suggestions are appreciated.
Old Aug 1, 2013 | 03:20 PM
rla2005's Avatar
rla2005
Replace the EGR tube....
Old Aug 1, 2013 | 03:53 PM
kevin206's Avatar
kevin206
Would that be the fix for my problem? I ask because my other truck developed a broken EGR tube and it didn't seem to cause any driveability issues.
The tube is on the fix-it list. I've neglected it simply because of the time it will take and the aggravation it will cause.
Old Aug 1, 2013 | 04:24 PM
stephen.osborne1's Avatar
stephen.osborne1
Fuel filter? Fuel pressure regulator? Fuel pump? Even a weak battery and/or alternator can cause similar issues at lower RPMs.
Old Aug 1, 2013 | 05:27 PM
RIKIL's Avatar
RIKIL
With the EGR tube broken you have air into your intake the engine isn't aware of. Once that is fixed, assess the situation and if something else is throwing off the motor, you'll find it.
Old Aug 1, 2013 | 05:47 PM
rla2005's Avatar
rla2005
Fix what you know is wrong before speculating on other causes of an issue. Otherwise you end up throwing $money$ at the problem until your wallet is empty.
Old Aug 1, 2013 | 06:08 PM
50dann's Avatar
50dann
Ignition module on the dizzy might be bad.
bebyb
Sep 7, 2014 09:53 PM
wtroger
Feb 26, 2014 09:44 PM
1990-f250
Feb 25, 2014 04:01 PM
zxsmyers
1997 - 2003 F150
21
Dec 22, 2009 12:54 PM
92 blue f-250
Nov 12, 2008 11:47 PM
