tracking down what is wrong
Old Jul 31, 2013 | 10:26 PM
2323foru's Avatar
2323foru
Hi.. I have really enjoyed this forum over the last 4 years and used alot of the tips and advise offered. I have an 1983 4x4 351w 2bl swapped to a 1986 with edelbrock 1406 4bl. I have had all the normal problems.... Lights going out on high beam.. hard to start when hot.... tilt steering. solenoid going bad and having to smack the thing to stop cranking etc.. but the one that has baffled me to date is the hard start when hot.. I am a prefectionist i guess and cheap as the day is long. I have tried to fix the hard start when hot problem by; replacing starter, battery, solenoid, cables, wrapping the exhaust, heat shiedling the starter, replacing all cables.... but.... i think the problem is boiling the gas out of the edelbrock 1406. I had dismissed this early on as a crazy idea that couldn't be... but after thought I have replaced the blocked EGR with a edelbrock aluminum spacer and put a good thick gasket between the spacer and the stock manifold and thin (because it was the only thing that would fit) between the carb and the spacer. After looking at the EGR spacer being hollow underneath I think thats a sign... Anyway, I love the truck but hate the engineering that makes it difficult to get "right".
spudgunman
Sep 1, 2012 10:50 PM
nminer1
Jul 18, 2011 10:50 AM
redman007
13
Jul 21, 2007 07:18 PM
mgarski
Sep 24, 2004 03:34 PM
ChopsMcgraw
Jun 4, 2002 04:21 AM
