Clutch bumper stop
Old Jul 30, 2013 | 11:13 PM
77f250weos's Avatar
77f250weos
Clutch bumper stop
Hi all
I got a 78 f250 with a manual 4 spd.
I trying to to check the clutch adjustment. But I have 2 questions
1. What is the procedure?
2. My clutch pedal bumper stop is so worn out , that I don't have a good starting point to check pedal free play. Is the bumper still available?
Thanks
Old Jul 31, 2013 | 06:22 AM
hickory1991's Avatar
hickory1991
Not sure if it's still available from Ford but am sure either Dennis Carpenter or LMC should have it.
Old Jul 31, 2013 | 07:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D3TZ-7583-A .. Clutch Pedal Bumper / Obsolete ~ 4,086 (!) available NOS ~ Carpenter has 4,024.
1973 F100/350 from serial number Q80,001 / 1974/79 F100/350 / 1975 Econoline.
Carpenter (800-476-9653) has it listed on page 30 in his 1967/79 truck repro parts catalog (2011 paper version).
Old Jul 31, 2013 | 08:24 AM
77f250weos's Avatar
77f250weos
Thank you Hickory and Number Dummy
Old Jul 31, 2013 | 08:26 AM
77f250weos's Avatar
77f250weos
BTW, does anyone know how many bumpers for this applications, I read some where it takes 2 of these. Does that sound correct?
Old Jul 31, 2013 | 04:19 PM
NumberDummy
Carpenter says 2, one for the brake, one for the clutch. But the '73/79 Ford truck parts catalog says clutch pedal only.
Old Jul 31, 2013 | 05:57 PM
hickory1991
On my 76 f-250 only have one on clutch pedal, none on brake pedal.
Old Jul 31, 2013 | 06:46 PM
77f250weos's Avatar
77f250weos
OK,Thanks all.
Old Jul 31, 2013 | 07:46 PM
mark a.'s Avatar
mark a.
To check free play remove the spring off the fork and move the clutch arm back and fourth and see how much play is there before the throwout bearing is touching the psi plate's arms. The pedal doesn't really have anything to do with adjusting free play. You may need to tweek it a little if the pedal doesn't want to return, just be sure once the pedal is returning right that it does in fact still have free play at the fork.
Old Aug 1, 2013 | 12:37 PM
77f250weos's Avatar
77f250weos
How much free play should there be at the fork?
BigMightySam5600
Apr 18, 2019 02:32 PM
Rustyol79
Apr 7, 2017 11:59 AM
sonny1965
Jun 4, 2014 03:58 PM
yellow truck
Apr 5, 2009 03:08 PM
