1978 - 1996 Big Bronco
Phantom noise, Please help.
Old Jun 13, 2003 | 07:00 AM
acousticbill's Avatar
acousticbill
I changed rotors and brakes last weekend, now I have a squeak that will come and go. It will slow when I slow down. I took it to some one to see if they could find it but they could not get it to make any noise. By the time I got it home it was doing it again. Sounds like it is in the drivers front. I did not put new bearings in it because they looked fine, just cleaned and repacked them good. I'd think if it was a bearing it would be make a different sound and making it all the time. Any ideas what it could be?
96 EB
5.8
EBS
Old Jun 13, 2003 | 11:12 PM
steve83's Avatar
steve83
Sometimes, the clips that the brake pads press against get bent and can rub the rim. It might also be the brake dust shield.
Old Jun 15, 2003 | 08:15 AM
john1263's Avatar
john1263
Wink Phantom noise, Please help.
I had the same problem...The squeak is coming from the inner dust seal on the spindle shaft that ride against the rotor. If it doesn't seat properly it with start to spin and the metal washer in the seal will rub on the spindle and Walla, it chirps every time it spins. This drove me crazy the first time I did my brakes. Good luck.
Old Jun 15, 2003 | 09:22 AM
BroncoBlasta's Avatar
BroncoBlasta
hello i was having the same prob so i took the dust shield off an i have not had a prob with it sence it was because the dust shields rust up an some of the rust falls off an falls behind the rotor an gives you a skwheeling sound so check that out
also check out my forum i got on here maybe you could help me if i help you
Old Jun 15, 2003 | 10:20 PM
Seabisquit's Avatar
Seabisquit
It may be the 'tattle-tale' reminder clip on the brake pad...
Old Jun 18, 2003 | 05:07 AM
acousticbill
Just to finish this post, I pulled the hub off and it was the seals. One was cocked and rubbing. So now I am back on the road. Thanks guys.
Old Jun 18, 2003 | 05:20 AM
john1263's Avatar
john1263
Glad to help
