Worthwhile axle swap?
Old Jul 29, 2013 | 10:36 PM
Camper Special Gene's Avatar
Camper Special Gene
My 1965 F250 with 352 engine has a limited-slip axle with a 4:10 ratio.
I have a chance to get a standard axle (i.e. not a limited-slip) from a 1967 F250 with a 3:73 ratio.
Is this a straight forward swap into my '65 truck? My intention is to use this truck for long distance towing and I thought the 3:73 ratio would be better for that as far as gas mileage was concerned. I would keep the C6 auto trans already in the truck.
Thanks, Gene
Old Jul 30, 2013 | 10:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
How much will the highway MPG improve 3.73 vs 4.10? Maybe 2 MPG max.
And you're considering buying a pig-in-the-poke, as you don't know what condition the 3.73 is.
Old Jul 30, 2013 | 06:12 PM
SuperSabre's Avatar
SuperSabre
I think your axle ratio choice should depend on what you're towing (how much does it weigh?) and how fast you want to go. Ideally, you want to be in the max power rev range of your torque curve. It doesn't sound like you really need a limited slip differential. A 3.73 will certainly cut down some revs over a 4.10 while still pulling quite well. You might even get away with 3.50s. Are you sure your automatic is a C6? The Cruise-O-Matic that came with your 352 in 1965 was not a C6.
Old Jul 30, 2013 | 06:17 PM
69supercj's Avatar
69supercj
I agree with sabre, I'd opt for a set of 3:55's and they're fairly common in the limited slip version.
Old Jul 30, 2013 | 09:29 PM
NumberDummy
OP has a 1965 F250 w/a Dana 60. What was the first year that 3.54 gears were available?
1966: This ratio is very hard to find thru 1972, difficult to find 1973/85. Many people want 3.54's, few find them.
1980: 3.07 & 3.23 gears were first offered in Dana 60's, lotsa luck finding either!
And, if the rear axle ID tag is missing (as usual), how would one know what the ratio is?
AXLE code stamped on the Warranty Plate, but a parts catalog is required to decode it.
Old Jul 30, 2013 | 09:35 PM
1972RedNeck's Avatar
1972RedNeck
1980: 3.07 & 3.23 gears were first offered, lotsa luck finding either!
Won't these only fit in the Dana 61's?
Old Jul 30, 2013 | 10:09 PM
Camper Special Gene
Re: worthwhile axle swap
Bill: I know the junkyard truck with the 3:73 runs and drives so I think the axle should be ok.
Supersabre: my 65 F250 should have a cruise-o-matic, but somewhere along the line it was replaced with a C6.
I would be towing a small lightweight antique car to shows (car weighs no more than 3,500 lbs. Say 3,000 lbs for a trailer (haven't bought that yet) for a total of 6,500 lbs or so. So I need the truck to tow, lets say 7,000 lbs long distances, to include some steep hills (eg. Vermont)
So far, it sounds like the switch over (if it would work) is not worth the effort to gain approx. 2 miles per gallon in gas savings.
The junkyard truck with the 3:73 is readily available and I'm pulling other stuff off it--just thought the axle would be worth while too.
Gene
Old Jul 31, 2013 | 03:23 PM
charliemccraney's Avatar
charliemccraney
2 mpg is significant in these trucks. If you get what seems to be an average of 10-12 now, 2mpg is a 16-20% improvement. You can't know for certain if the swap will improve mileage until yo do it. If it does, it should be pretty cheap and pay off quickly.
Old Aug 17, 2013 | 09:40 PM
pm042070's Avatar
pm042070
I have a 1966 F250 with 460 engine and C6 transmission. I changed the 4.10 gears to 3.54 and mileage increased from 8 MPG to 10 MPG. I added headers and increased MPG to 11. The 3.54 gears weren't hard to acquire. Local Carquest ordered them and had them by next day. Towing 12,000 lbs of hay was still no problem for the truck either. Hope this helps.
Old Aug 17, 2013 | 11:42 PM
rogue40's Avatar
rogue40
With a C6 I think I would go with something in the 3.50 range but 3.73s might be a decent compromise.
I would sell that 4.10 rear end.
Old Aug 18, 2013 | 05:48 AM
jowilker's Avatar
jowilker
Gene
Gene, I would hook that to my 66 F100 FE C6 9" with 3.25 any day of the month and not sweat it a moment. I do have a puller up front and that is where it's important.
John
ClarkM
2015 - 2020 F150
16
Sep 17, 2024 04:06 PM
kabur66
6.7L Power Stroke Diesel
20
Sep 10, 2020 08:31 AM
MKEBoost
2009 - 2014 F150
19
May 16, 2012 09:11 PM
santana157
2009 - 2014 F150
25
Mar 14, 2010 12:24 PM
coleyct
13
Mar 29, 2005 10:27 PM
