Need guidence with codes
  #31
Old 08-02-2013, 05:34 AM
dieselsubmariner's Avatar
dieselsubmariner
dieselsubmariner is offline
checking resistance as in test 1, you are measuring across the injector itself. If you get a reading of zero, you either have the meter not set up, or the plugs on the head (the pigtails ) unplugged. you should be reading around 2.9 ohm. the other possibility would be all harnesses bad, which is unlikely. Test 2 and 3 need to come up open(no reading), as you are measuring for a short. but since test one came out all zero, 2 and 3 are in question.
please double check if you can. If you have a reading in test 2 or 3, check your harnesses under the valvecover. if you not reading anything on one of the connections for the injectors, you also need to investigate further for wiring damage.
If the test comes out good, suspect the IDM bad.
hope that helps.
if you need to , pm me and i can talk you through on the phone sometime this afternoon
  #32
Old 08-02-2013, 10:06 PM
pilgrimbizket's Avatar
pilgrimbizket
pilgrimbizket is offline
Today I pulled BOTH valve covers, all connections looked good.
I bought a new multimeter, I got the same readings as my old one.
I went to my local scarp yard and paid 200 for an IDM out of an 01
I will install it tomorrow and pray my problems are solved
  #33
Old 08-03-2013, 03:26 PM
pilgrimbizket
Well the new IDM is installed.
I still have a CEL, I cleared my codes too I have only driven about half a mile.
Everything seems to be back to normal the truck is idling normal again. Its defiantly drivable, just something doesn't sound right Im probably being a worry *****. Im going to replace rear hub seals and take her for a good 25 mile drive. I hope the CEL clears it self.
maybe some air in the system??
  #34
Old 08-03-2013, 04:55 PM
dieselsubmariner
I'm glad the idm made it run better. . But now you should get it scanned again to see what else is going on. Since the cel is on , a auto parts place should be able to scan it .
  #35
Old 08-03-2013, 08:47 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
No auto parts stores can scan our trucks. Generic cheapo scanners don't work on these.
  #36
Old 08-03-2013, 08:51 PM
dieselsubmariner
i thought, they can read the active codes, that set of the cel only. but i might be mistaken :-)
  #37
Old 08-03-2013, 10:10 PM
pilgrimbizket
Yeah something is still wrong, after replacing the hub seals I only drove a mile.
I don't feel comfortable driving it, I am probably just over thinking it.
But so after replacing the IDM, its corrected 90% of the problem.
What else could be going on here?
  #38
Old 08-04-2013, 08:26 PM
pilgrimbizket
Turned out I had forgot to plugin one of my pigtails. She runs great no more CEL
  #39
Old 08-04-2013, 08:46 PM
dieselsubmariner
That's great to hear . At least you got her back running again . I ran into some roadblocks on my truck , but that's on my dually report.
cutlass
13
03-11-2024 11:59 AM
bkuuz1
12-03-2013 03:33 PM
Wiredoge4
01-13-2012 01:07 PM
jmaskew
08-21-2011 05:47 AM
ZeroAccess
09-15-2008 04:07 PM
Quick Reply: Need guidence with codes
