Couple of thoughts: adding your location to the User CP profile, will allow a better sense of your geography. Also, have you been cruising Craig's List and the classified listings on this site? Fenders are hard to come by - especially when they were produced for only a few years. You may need to consider searching for a parts truck, if you haven't already done so. There is a certain amount of harvesting that needs to happen to keep these beauties on the road.
I have one, but it has quite a bit of bondo and fiberglass on it at the seam between the two parts. The previous owner had bondo and fiberglass covering the seam between the two to cover the rust. It is repairable, but would take some patching. Where are you located? If you come pick it up you can have it.
i have a friend in oregon that may have or know where to locate one. if your in that part of the country…
please take some time and give us a rough guess of your location. it helps when looking for assistance or parts..
