c2 - c6 trans swap
Old Jul 27, 2013 | 11:55 AM
Twanstyle's Avatar
Twanstyle
c2 - c6 trans swap
is it possible or am i dreaming
cant loose the 3 on the tree
300 I6
c2 trans as the plate says
Old Jul 27, 2013 | 12:33 PM
lafermedavid's Avatar
lafermedavid
trans swap
c4,,,,what size motor
Old Jul 29, 2013 | 10:02 AM
Old Coyote's Avatar
Old Coyote
I'm in the process of replacing the 3-speed manual in my 75 (300 6 cyl), with a C4, and I've read a fair bit of stuff on this topic, so I may be able to help. But, I'm not certain what your question is. What is your problem or what is it you want to do?
Old Jul 29, 2013 | 01:13 PM
Twanstyle's Avatar
Twanstyle
I found a used c6 basically wondering if I can keep my 3 on the tree and still swap the trashy since mine feels a lil tired at times
Old Jul 29, 2013 | 01:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Twanstyle
is it possible or am i dreaming cant loose the 3 on the tree / 300 I6 / C2 trans as the plate says
No such thing as TRANS code C2, it's just C / The 2 is the first digit of the AXLE code that follows the TRANS code on the Warranty Plate.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
Steering column with an A/T is different than with 3 M/T. Shift tube, shift collar different, as is the mast jacket.
Bottom of the steering column has selector levers. A/T has one, 3 M/T has two.
1978 was the first year that the 300 & 302 were available w/a C6, but the C4 was also available. NSS mounts on the transmission, C6 uses a different NSS than C4.
1967/77: NSS mounts on the steering column, same for all A/T's.
Old Jul 29, 2013 | 02:25 PM
Old Coyote's Avatar
Old Coyote
The most common C series tranny that will bolt to your 300 engine is a C4. Even then, you have to be sure the tranny has the right bell housing as it may have a big bell or small small bell. You'd need the small bell. As for the C6, I understand they are out there with a small bell, but they are rare. Bill is usually right about these things, and he says they only started making a C6 that would bolt to the 300 in '78. I guess if you can find one, well done. If not, you may want to consider a C4.
I don't understand what you mean by asking "if I can keep my 3 on the tree". Do you mean can you keep the gearshift? I don't know. I never tried. I just swapped in the automatic column shift when I changed the transmission. If you don't have access to one of those, you might consider installing a floor shift. There are kits, and I've seen fabricated ones that do the job too.
Old Jul 29, 2013 | 02:35 PM
Twanstyle's Avatar
Twanstyle
I think bill nailed it again thanks guys
Old Jul 29, 2013 | 03:06 PM
Old Coyote's Avatar
Old Coyote
And just so you know, if you are doing this swap, you will also need to replace your current flexplate with the right flywheel for the automatic tranny, and that flywheel will also have to be specific to your engine because of balancing specs. You'll also need to swap the starter. And you'll need a radiator with a tranny cooler as well as the cooling lines. And you'll need a set up for the accelorator-tranny kickdown. I'm not trying to discourage you, just speaking from experience that there's a lot of things in addition to the gearshift to think about.
Old Jul 29, 2013 | 03:07 PM
Old Coyote's Avatar
Old Coyote
Actually, I meant to say replace your flywheel with a flexplate (but you get the idea).
Old Jul 29, 2013 | 03:19 PM
NumberDummy
What's does the C (series tranny) refer to, the year of introduction? C4 was intro'd in 1964, C6 was intro'd in 1966.
When was the C3 intro'd? Not in 1963! C5 wasn't intro'd in 1965 either.
The IDIOTS used the G Warranty Plate TRANS code for all A/T's thru 1978. One had to know what tranny was available with which engine.
IDIOTS finally wised up in 1979: G = C4 ~ K = C6 // 1980/82: J = C4 / 1980/89: K = C6
76EconolineND
Jun 21, 2013 09:17 PM
jgavac
Nov 12, 2010 09:37 AM
F-250 restorer
Jul 2, 2010 04:17 PM
