Interesting Issue
Old Jul 26, 2013 | 08:13 PM
fjspinelli's Avatar
fjspinelli
Interesting Issue
I have a 2006 F350 with a 6.0 Diesel. I have done the head gaskets and replaced the egr, oil pump, etc.. I am having an issue similar to stiction described in other posts, before the truck is warm. However,recently the bucking and timid throttle response before increasing RPMS is getting increasingly worse. Do we think fuel pump, water, or clogged fuel filters? going to replace the FCIM at first chance, but we are on a trip and I want to patch the issue if I can.
Input please,
Thanks,
FJ
Old Jul 26, 2013 | 09:30 PM
Yahiko's Avatar
Yahiko
I think you need to have some live data before you start
tossing parts at it. A set of gauges or a Scanguage II
and program in the Xguages would be my first step.
Sean
Old Jul 26, 2013 | 10:22 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
How long since you did the work? If it was recently, you might want to check that the connectors on the FICM are seated and clicked.
Did the CEL light come on?
Old Jul 26, 2013 | 10:40 PM
fjspinelli's Avatar
fjspinelli
The Banks have been in since 105k. Other work at 100k. Had truck on computer less than a month ago and have no current or stored codes. Thinking fuel pump, but dont understand warm up change if evetything is electronic.
Old Jul 26, 2013 | 11:00 PM
BLADE35's Avatar
BLADE35
check battery cables
Old Jul 27, 2013 | 04:02 PM
Mich6.0's Avatar
Mich6.0
Original batteries ? FICM volts got a scan guage ? Fuel fiters ever 15K
Old Jul 27, 2013 | 04:47 PM
BLADE35's Avatar
BLADE35
it sounds like stiction
you maybe able to clean all Injectors spool Valves to help things
Also Used 5w40 Full Synthetic oil
you can get some additive for your Oil But I cant think of the Name of it (ITS NOT Hot Shots Secret though)
Its the other one and its a Lubricant what helps the Spool Valve Move
There is a Procedure for cleaning the injector spool valves in the Tech Folder check it out
Whats the Oil Additive Im thinking about Guys???
Its on the tip of my toungue
Old Jul 27, 2013 | 09:35 PM
daddykitty's Avatar
daddykitty
archoil for oil and fuel
Old Jul 27, 2013 | 10:01 PM
Rusty Axlerod's Avatar
Rusty Axlerod
.....RevX?
Old Jul 27, 2013 | 10:09 PM
Fal-308-Win's Avatar
Fal-308-Win
.........Olive Oyle????......
Old Jul 27, 2013 | 10:50 PM
daddykitty's Avatar
daddykitty
somebody started drinking early tonite
Old Jul 27, 2013 | 11:29 PM
BLADE35's Avatar
BLADE35
Originally Posted by Rusty Axlerod
.....RevX?
This one^^
Its a Lubricant I really liked what I heard about this one so far
IDK What Archoil is
Definatly don't go with Hot Shots its Bananas (Potasuim)
Stgermaine
6.7L Power Stroke Diesel
17
Mar 15, 2016 04:57 AM
idlewild
1983 - 2012 Ranger & B-Series
Aug 10, 2015 03:10 PM
IndySilverAnny
Jun 5, 2008 05:49 PM
JBronco
1978 - 1996 Big Bronco
Sep 27, 2006 06:04 PM
