Sponsored by: Auxito
Major Electrical issue!! HELP
Old Jul 25, 2013 | 11:06 PM
aabirdman's Avatar
aabirdman
Thanks for viewing. Ok Jump in the truck this morning . drop off the trailer, pick up hay, stop and get a soda. Jump back in and nothing. No lights, no bells No nothing. Sat for a minute and the pats would come up but no starter, no radio. Finally it would click om start, like a bad solenoid, but no turning starter.
Drag it home. Through it on the charger just to make sure i was working with a full battery. Changed the Pos Batt terminal, and still no start. I now have a relay that is chattering and the Interior lights and the engine bay light blinks.
Again thanks for looking
aabirdman
Old Jul 25, 2013 | 11:08 PM
aabirdman's Avatar
aabirdman
Wrong truck on profile. 2000
f150 5.4l
Old Jul 26, 2013 | 12:03 AM
Bluegrass 7's Avatar
Bluegrass 7
That's what you get for stopping for a soda then you would not have to have a tow.. hi hi.
Don't stop there.
There is a neg post, the rest of the cables and the other ends/connections etc..
There is a start relay and it's cable to the starter.
The starter could be jambed etc.
The battery could have an open intercell connector etc.
If there is no or little power anywhere the battery source of power is nearly open circuited. Said another way, to high a voltage drop.
Happens to the best of em at anytime.
Good luck.
Old Aug 18, 2013 | 10:26 AM
bigdtd's Avatar
bigdtd
change the neg terminal as in above post.
Old Aug 18, 2013 | 02:07 PM
96f150's Avatar
96f150
I would throw a meter on it and see what your voltage is WITHOUT the charger hooked up. Then try cranking it over and see what your voltage falls down too
Rich
Old Aug 18, 2013 | 02:55 PM
Bluegrass 7
birdman, the thread is month old.
Where you at with your issue?
Others would like to know if you solved your issue.
Old Aug 23, 2013 | 01:28 AM
aabirdman's Avatar
aabirdman
Sorry Guys. First Battery was a dead player. Had to replace the positive terminal, coroded to almost nothng. Then the neutraul teerminal went. Seems to be working fine now. Thanks for the input.
92will460
Jan 17, 2014 11:59 AM
williambaker
Aerostar
13
Sep 30, 2013 02:04 PM
Miera85
1983 - 2012 Ranger & B-Series
Jul 4, 2013 06:45 AM
padd54
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 14, 2012 03:53 AM
dan1101
Aug 19, 2006 01:14 PM
