6.0 shut off while driving
Old Jul 25, 2013 | 08:01 PM
freakville03's Avatar
freakville03
I was driving home tonight and my 2005, 6.0 just shut off. Tried to re-start it, but it only turns over and does not start. I checked all the fuses and they are good. I checked the fuel pump under the drivers seat and it is working. I have a little pocket scanner and it shows no codes. So now I'm clueless. Please help.
Ken
Old Jul 25, 2013 | 08:55 PM
dlibson's Avatar
dlibson
Got anything to read data?
Old Jul 25, 2013 | 08:57 PM
freakville03
I have nothing to read or data.
Old Jul 25, 2013 | 09:17 PM
freakville03
I have nothing to read or any data. Any ideas?
Old Jul 25, 2013 | 09:21 PM
big inch's Avatar
big inch
Without much to go on yet, I would venture a wild guess that the stc fitting failed.
Old Jul 25, 2013 | 09:24 PM
freakville03
Can you tell me what other info you are needing?
Old Jul 25, 2013 | 09:33 PM
big inch's Avatar
big inch
The first thing would be to monitor a few pics while cranking like ICP, IPR, rpm and FICM sync. If ICP isn't over 500, then you would need to do an air test to locate the leak.
Old Jul 25, 2013 | 09:40 PM
freakville03
I'm thinking that I would have to take it to the shop. I'm not sure of anything that your speaking of. Unless you can assist me.
Thank you
Old Jul 25, 2013 | 09:44 PM
mustang_309's Avatar
mustang_309
You need some gauges that read live data, like scan gauge II or one of the smartphone apps, like dashboss for IOS devices or torque pro for android. The scan gauge can be had at autozone for around 160 bucks.
Old Jul 25, 2013 | 09:54 PM
big inch's Avatar
big inch
We can help walk you through the diagnostic process, but if you aren't very familiar with the 6.0, or very mechanically inclined, then you may want to consider finding a reputable diesel mechanic in your area.
These engines aren't too bad to work on once you've seen a few thousand of them, but they can be fairly complex for a first timer.
Old Jul 25, 2013 | 10:00 PM
Joe Rodawold's Avatar
Joe Rodawold
Happened to me also Ford dealer said it was the crank sensor replaced it and didn't start wound up being a hiflow pump. While the engine was open we also did an EGR delete to the truck. Runs great now. Jim's Powerstroke in Chanahon did the work.
Old Jul 25, 2013 | 10:01 PM
freakville03
I can work on engines and have overhauled them, but never on a diesel.
Old Jul 25, 2013 | 10:03 PM
Joe Rodawold
His number is 815-280-8496. Illinois time is one hour behind you he is usually at the shop by 7:30. He can walk you through the process.
freakville03
That sounds pretty pricey.
cheezit's Avatar
cheezit
nuts and bolts. they havent changed in better then 100 years. you just dont have spark plugs
