Resetting codes.
Old Jul 25, 2013 | 07:48 PM
Alex from GA's Avatar
Alex from GA
Resetting codes.
On my wife's '99 Explorer, she just acquired, we had a P0303, #3 cylinder misfire. I found the plug cracked and replaced it. Do the codes reset themselves or do I have to do it? I'd rather not disconnect the battery and reprogram the radio. Thanks.
Old Jul 25, 2013 | 08:09 PM
shorod's Avatar
shorod
The light will go out soon, after the PCM is able to confirm the misfire is no longer an issue. But, keep in mind that the PCM will store the P0303 code as a history code for quite some time. That's really only an issue if you take the truck to a shop for some possibly related issue in the future, they scan the codes, find a misfire code, and charge you to replace all your spark plugs and wires.
You could also call around to the local parts stores. Often parts stores will have a scan tool that they can use to clear the diagnostic codes without resetting your radio stations, etc. Preferably, start with the store you bought the replacement spark plug from.
-Rod
Old Jul 25, 2013 | 08:40 PM
Alex from GA
Thanks, that's what I was looking for.
Old Jul 26, 2013 | 05:34 AM
projectSHO89's Avatar
projectSHO89
It's easier to just pull the single fuse that supplies Keep Alive Memory (KAM) power to the PCM for 10 minutes to reset the PCM. It's usually a small value fuse, 5A or less. See owner's manual.
Old Jul 26, 2013 | 07:24 AM
Alex from GA
I checked the owners manual and couldn't find a fuse that said that in either fuse panels. Another forum said pull the #11 maxi fuse, under the hood and they only went up to 10. I purchased a scanner and I'll clear the codes from there when it arrives.
Old Jul 26, 2013 | 03:17 PM
projectSHO89
Try fuse F6 under the hood for the 99 Exploder.
Old Jul 28, 2013 | 01:18 PM
Alex from GA
My code reader arrived last evening so I erased the code.
Old Jul 28, 2013 | 05:02 PM
projectSHO89
You would still do well to reset the PCM since that also resets skewed fuel and shift tables back to defaults.
Resq202
Modular V8 (4.6L, 5.4L)
Jun 27, 2012 10:01 PM
broken ford truck
1997 - 2003 F150
Jul 1, 2010 09:19 PM
tr0y
Apr 18, 2010 07:40 PM
socalexpy
1997 - 2003 F150
Jun 4, 2007 04:07 PM
laidbacksouthern
1997 - 2003 F150
Oct 24, 2004 10:56 AM
