Vibration
Old Jul 25, 2013 | 10:47 AM
sleep_deprived129's Avatar
sleep_deprived129
Vibration
I have a '70 F-100 with a C4 and a 9". It has developed (or has always had without my notice) a vibration at around 65mph (I do not drive the truck on the highway very often, which is how it would have escaped my notice until recently). The wheels are balanced, the driveshaft is balanced and has new u-joints and carrier bearing but the vibration persists. I feel it in the wheel but it also seems to shake the whole truck, I am going to have someone drive next to me and see if there is any obvious wobble. Other than that, any ideas where to look next? Perhaps a loose/worn component in the steering? Rear end? Thanks in advance for any and all help.
Old Jul 25, 2013 | 02:32 PM
JEFFFAFA's Avatar
JEFFFAFA
Check these:
1. belt separation in one of the tires. (air pocket lump in tread or sidewall)
2. loose lug nuts
3. loose wheel bearings
4. bad front shocks. front tires actually bouncing while you are driving
5. since you feel it more in the STEERING WHEEL the problem should be from the front. Just in case, a bent rear axle can cause it.
BTW GO SUN DEVILS!
Old Jul 25, 2013 | 02:54 PM
sleep_deprived129
Originally Posted by JEFFFAFA
Check these:
2. loose lug nuts
The tires are relatively new and recently balanced so I would hope it is not number one or two and the brakes were also recently done which would in theory rule out number three (though nothing surprises me with quality control anymore). It has been feeling a little soft in the front so the shocks are worth a check, any thoughts on the problem being a tie rod end or other steering component? I can't say I've ever replaced or even looked at those recently.
BTW GO SUN DEVILS!
Everyone is entitled to their opinion...even if it's wrong
Old Jul 25, 2013 | 05:02 PM
raytasch's Avatar
raytasch
Believe Nothing
Some of these series trucks had a cast iron plate attached to the rear of the cab as a vibration damper. I may be off on the years a bit but I remember seeing it on one of my trucks back when. And thinking about vibrations, is your C4 equipped with the add on vibration damper ? Some have it, some do not.
Old Jul 25, 2013 | 05:08 PM
JEFFFAFA's Avatar
JEFFFAFA
I would still check 1 through 3. Once I bought a set of Goodyears to put on a car I was turning. I just happened to look at one of them before they were getting mounted and notice a sidewall looked wierd. On closer inspection I found a hole in the inner belts about the size of a half dollar! The only thing that was there was the inner and outer layer of rubber. As far as the lug nuts goes, the tech who mounted the tires is human. And if he re-packed the bearings I repeat, he's human.
The linkage? That usually causes a "wander" or grabbing any crack in the road. Not usually a vibration.
Old Jul 25, 2013 | 07:51 PM
RichS2659's Avatar
RichS2659
Coil-sprung Ford with a vibration? Death Wobble? Check your radius arm bushings as they are probably so cracked and worn out. No body thinks of those whether 2 or 4wd.
montana_highboy
21
Sep 22, 2017 03:47 PM
ponch37300
Jul 18, 2008 03:03 PM
Limited 95
2004 - 2008 F150
Nov 18, 2005 08:31 PM
Ford-man22
2004 - 2008 F150
39
Oct 30, 2005 12:48 PM
Horse lover
1997 - 2003 F150
Apr 21, 2005 04:02 PM
