Offroad & 4x4
Caster settin?
Old Jun 12, 2003 | 07:41 PM
Ryan50hrl's Avatar
Ryan50hrl
Caster settin?
quick guys,,,i need to know what to set my caster at for my 79 F-150 dana 44 thats going into my 95. What was the spec for a 79 4x4? Thanks
Old Jun 12, 2003 | 09:05 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Caster settin?
Do you mean the castor built into the diff yokes or alignment castor?
If you're talking about alignment, I can't say what factory specs are but in researching the subject I read that you want no less than +2* and no more than +8*. For what it's worth.......
Old Jun 13, 2003 | 09:45 AM
Ryan50hrl's Avatar
Ryan50hrl
Caster settin?
i'm looking for alignment caster. I can't seem to find a factory spec listed anywhere.
Old Jun 13, 2003 | 03:25 PM
RCrawler's Avatar
RCrawler
Caster settin?
According to my book, you want 6.5- 9.5 +, +8 preferred.
A footnote says for 3 1/2" ride height (bumpstop to frame). Subtract 2* for each 1" over ride height.
Jason
Old Oct 10, 2008 | 03:17 PM
Henrys son's Avatar
Henrys son
Whats the castor setting on f250 D44 1976 yoke and alignment castor.
Old Oct 10, 2008 | 06:33 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
holy thread miner.....
-bump-
Old Oct 10, 2008 | 07:29 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
isnt that the same question as the op...
Agree with thread mining, but stuff that old had to use the search function!
Which is comforting!
Old Oct 11, 2008 | 12:41 PM
Henrys son's Avatar
Henrys son
yes ,some people search.Thanks .
Old Oct 13, 2008 | 11:31 AM
TN97STROKE's Avatar
TN97STROKE
If you are using the radius arms from the 79, you should look at the angle of the arms.
At factory ride height the arms would be about level with the ground, and have about 6 deg. of castor. Now with every inch of lift on the factory coil spring/radius arm suspension you will loose 1.2 deg of castor. Now with that being said every inch you lower the radius arms down from the frame you will gain 1.8 deg. of castor. So for 6 inches of lift you get (start with 6 deg.) 6" X 1.2deg = 7.2 Now take the +6 -7.2 = -1.2 of castor, now use 6 deg. c-bushings you will be at +4.8 of castor. now lower the radius down 1 inch (= 1.8deg) 4.8 + 1.8 = 6.6 deg. and you will be close.
Hope this helps.
Old Oct 13, 2008 | 02:06 PM
Henrys son's Avatar
Henrys son
Thanks 97 .Good info .I dont have radius arms thought ,just leaves.
Anyone have an Auto digest with all the specs of different vehicles?
Old Jun 11, 2009 | 09:01 PM
jenkinsj's Avatar
jenkinsj
I welded a 77 4x4 front end on my 64. I took it to get it aligned and they told me that my caster was off and 77's had not adjustment. The truck wanders a bit going down the road. The shop told me that caster allows for the wheel to come back to center? I have replaced all of the steering components even the gear box. Does the caster come in the radius arms? I just bolted them up to the frame. Can I drop them down a bit to get the proper caster?
Thanks.
Jack
Old Jun 11, 2009 | 11:46 PM
9.ford.5's Avatar
9.ford.5
caster is measured on the flat top of the knuckle you want at least 2* + caster no more that 8* i believe ideal for these things is 4.5*-6.5*+ which means if you measure from the d/s knuckle it will be rotated clockwise (or backward) from 90*
proper caster will allow the wheels to return to center and it affects handling and pinion angle (the angle of the drive shaft in relation to the pinion angle of the diff)
by lowering your rad arm mounts you will gain + caster...you can also buy caster corrected "C" bushings that are between the rad arm and the wedges on the axle for instance 7* C bushings give you 7* of + caster...this is if you have a big lift but you can buy them in all sorts of different measures
caster does not change with lift, ideally you want your caster to be between 4.5*+ and 6.5*+ no matter what, when you lift the truck it will change the caster measure that is why for anything lifts 4" or higher you need rad arm drop brackets or other forms of caster adjustment
Old Jun 13, 2009 | 07:39 AM
jenkinsj's Avatar
jenkinsj
Thanks for the reply. I talked to my alignment guy and he said right now my caster is 0 and should be +2 degrees. I just happen to have a set of 2degree bushings I bought 5 years ago when I did the modification so I am going to put them on this morning.
Jack
AvdDrift
Dec 18, 2014 10:04 AM
artieb
Apr 12, 2014 04:13 PM
Metrojd
Feb 26, 2014 05:50 PM
FossenRacing
Feb 10, 2013 08:46 PM
jimmycoc
Aug 25, 2011 08:44 AM
