New to the forum. Bought a 65 custom cab short bed the other day with the intentions on building a nice date truck for the wife and I. Anyway, the VIN is as follows:
F10DR615621
Any help is greatly appreciated! Thanks in advance.
115..wheelbase in inches
T...exterior color+ Sandshell Beige
F100...1/2 ton 2WD truck with a 5000# max GVW
Body..481..4= Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl
81=81A= base model truck
Trans...A= Manual Light Duty 3 speed Transmission
Axle...07= 3:50 ratio open rear end gear, non locking
DSO...75= Phoenix...Where the original selling dealer ordered the truck from.
This was not a special order truck, it was bought off the lot.
Trans A = Manual Light Duty 3 speed Transmission
Axle 07 = 3:50 ratio
A = Ford type 3.03 3 Speed Manual Medium Duty (OP has a 352, not an I-6) all Syncromesh Transmission.
07 = Ford 9" Rear Axle / 3.25-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
08 = 3.50-1 / AXLE code 17 was used 1966/77 for 3.25-1.
Originally Posted by Retired EOD
I also have a 65 F100 and was wondering what COLOR code FM & BODY code B81 decodes to.
FM: F = Light Blue / M = Wimbledon White.
B81: B = Medium Blue Crush Vinyl & Medium Blue Ladder Pattern Woven Plastic // 81 = 81B Custom Cab.
Originally Posted by bakednaz
It has Custom Cab door handle guards and a tool compartment in the right (passenger) side bed (quarter) panel. Is this all non original?
Both were either available as a factory installed option or a dealer installed accessory / My purchased new 1965 F100 Standard Cab 8' Styleside came with the tool compartment factory installed.
Pics from the 1964/72 Ford Truck Parts Catalog ~ The door handle guards were introduced in 1963.
1964/66: Two different lengths of tool compartments were available, one for the 6 1/2' bed, one for the 8' bed.
