1988 E250 GCWR?
Old Jul 23, 2013 | 09:24 PM
jayro88's Avatar
jayro88
1988 E250 GCWR?
Hello,
I am trying to find what my '88 E250 GCVW is? I searched and found all kinds of definitions, but no chart anywhere. I am going to be buying a Travel Trailer in the future and was trying to narrow down the weight range to look at. I have my vehicle manual and for my engine/gearing/trans combo it has 3 different GCVW listed. On the different Ford websites I was not able to find anything listed far enough back. I also tried running my VIN and it keeps saying it is an error......even though I have triple checked it. Any ideas?
1988 E250 7.3IDI
3.54 gears c6 <!-- / message -->
<!-- sig --> __________________
Old Jul 24, 2013 | 05:07 AM
senix's Avatar
senix
What is on your door cert?
Old Jul 24, 2013 | 07:51 AM
jayro88's Avatar
jayro88
It doesn't have the GCWR, it just has the GVWR which is 8500lbs and the front/rear GAWR.
The vehicle is as follows:
1988 e250 ClubWagon 2wd
7.3 IDI Diesel
c6 trans and 3.54 gears
It also has a frame mounted hitch, brake controller and auxiliary trans cooler added in series with the stock radiator one ....will have a weight distribution and anti-sway as well.
Old Jul 24, 2013 | 08:01 AM
senix's Avatar
senix
What is the axle rating then? You should get it on the scales to be sure of what it acctually weights empty.
E-rated LT tires? I would want them over P tires.
Based upon what you have indicated I think something around a gross of 8K for a TT would be ok.
I don't think I would want more.
Old Jul 24, 2013 | 09:01 AM
jayro88's Avatar
jayro88
The axle rating is 6340lbs. I will put it on the scales to find its weight, but I think it is somewhere in the high 5k low 6k area, It was about 6.5k at the scrap yard scale with an empty double snowmobile trailer.
It has E-rated LT tires, 7-pin/brake controller and a frame mounted hitch w/2" receiver (not sure of the class. Secured by 2 bolts each side, may upgrade).
I will be adding a weight distribution hitch and anti-sway along with a Trans Temp gauge, EGT and Coolant temp gauge.
Wanting to set it up for a nice vehicle to take road trips/vacations in for the 5 of us. Lots of interior room and a TT to stay at campgrounds when needed......plus my son plays travel soccer and staying at hotels for weekend tournaments can get expensive with the whole family.
Old Jul 24, 2013 | 09:10 AM
senix's Avatar
senix
I think 8 K gross is gonna be about it. That would give you a tongue wt of 850 lbs. 850 lbs goes against your cargo/payload in the van.
You can save a bunch by doing campground/dry camping on those trips. We stay lot at Walmarts and stuff and then every third night at a campground so we can dump and resupply fresh water.
Old Jul 24, 2013 | 09:33 AM
jayro88's Avatar
jayro88
Thanks, that is kind of my thoughts, just wanted to check with the "Experienced" people. Adding the 850lbs to vehicle curb weight along with 5 people, another 600lbs, and whatever luggage etc we carry in the van would put us fairly close to the GVWR of 8.5K.
I am thinking of about a 30ft TT with couple of slide out. Still debating on a bunkhouse style, or having the kids sleep on the couch/dining etc beds. Leaning toward the bunk house style for them. Ages 5,9 and 11.
fastfred49
Jan 4, 2014 01:08 PM
jayro88
All Things Towing
19
Feb 2, 2013 10:30 AM
antirice
Jan 23, 2011 12:17 AM
hogbus
Oct 8, 2009 07:03 PM
weldingfreak
All Things Towing
Jun 13, 2004 09:04 AM
