ICP Plug Causing Truck Shutoff?
Old Jul 22, 2013 | 06:03 PM
Nabors's Avatar
Nabors
I was told to wiggle the plug by a helpful person on this forum and it didn't do anything. The other day I did it again and it made the truck almost shut off, then jump to high idle, then shut off. I have a pigtail here. Should i replace it?
Old Jul 22, 2013 | 06:18 PM
Shake-N-Bake's Avatar
Shake-N-Bake
If wiggling the harness caused the engine to run erratically then I would fix or replace the wiring.
Old Jul 22, 2013 | 08:14 PM
F350-6's Avatar
F350-6
What does the old connector look like? If you've got a spare pigtail, there's no harm in changing it. Make sure you didn't lose the little rubber seal on the end of the plug. If you did, just take the one off the new pigtail, stick it on the old connector (if it looks good) and do the wiggle test again.
Old Jul 22, 2013 | 08:15 PM
Nabors's Avatar
Nabors
Are you talking about the little spring looking rubber piece that is like the weather guard?
Old Jul 22, 2013 | 08:21 PM
JOHN2001's Avatar
JOHN2001
Just so I know if I understand correctly... A properly working icp sensor when the truck is running and icp is unplugged the truck should sputter and catch itself, correct? Sorry for the hijack.
F350-6's Avatar
F350-6
Yes. If that falls off, the connection becomes too loose and can cause problems. Especially when you wiggle it or hit a bump.
Old Jul 22, 2013 | 08:27 PM
Nabors's Avatar
Nabors
When i wiggle it, the only time it happens is when i press it to the side. When I push it straight down it is perfectly fine. Oddly enough, when the truck shut off I was going around a bumpy turn.
Old Jul 22, 2013 | 08:36 PM
Nabors's Avatar
Nabors
Sometimes it catches and then, like when it shut off, it sputtered and died but started right back up.
Old Jul 22, 2013 | 08:46 PM
JWC 3's Avatar
JWC 3
I would change the plug . And , if oil is in the sensor end , change it also .
eightOsix
All Things Towing
Feb 17, 2018 07:54 PM
Fixnstuff
Jul 14, 2017 09:47 PM
jimbbski
2009 - 2014 F150
Apr 2, 2017 11:50 AM
ithaca1230
Oct 28, 2013 02:59 PM
KopterDR64
All Things Towing
Oct 5, 2012 04:16 PM
