Leaking Master Cylinder
Old Jul 21, 2013 | 07:09 PM
GaryLP's Avatar
GaryLP
What I have, 78 F-150, long box, 2 wheel drive, warmed over 460, C-6, 3.50 locker rear axle, L & L headers. While in the body shop I put on a new brake booster and new master cylinder along with the headers. Now I am leaking or seeping fluid out of the master cyl. Seems to be coming out where the top gasket is. The brake lines are within an inch of the headers and the header is close to the proportioning valve. I am wondering if I am to close and boiling the brake fluid or if I have another problem? Would it help to go to Syn. brake fluid that has a higher boiling point?
Old Jul 21, 2013 | 07:13 PM
montana_highboy's Avatar
montana_highboy
Is this a vented m/c lid or non-vented?
Old Jul 21, 2013 | 07:20 PM
GaryLP's Avatar
GaryLP
Non - vented
Old Jul 21, 2013 | 07:25 PM
montana_highboy
Non - vented
That's why fluid is being forced out between the lid/reservoir gasket, source a vented lid....then you can top it off to the brim without any leakage.
Old Jul 21, 2013 | 07:59 PM
GaryLP's Avatar
GaryLP
I am just confused , I have owned the truck for 20 years and never had a problem till now???????
Old Jul 21, 2013 | 08:10 PM
montana_highboy
I put on a new master cylinder
Non - vented
From my own experience 90% of replacement M/C's (reman'd and/or new) come with a non-vented lid.... you fill it anywhere past half full and it's gonna leak past the gasket.
The original M/C lids are vented, you can top off the reservoir and they won't leak...
Old Jul 21, 2013 | 08:41 PM
gpence's Avatar
gpence
Last one got from the parts store needed to be sanded to smooth out the mating surface between the MC & the lid. And I still think it wouldn't hurt to maybe put a little hedder wrap around the brake lines or let's move them away.
Old Jul 21, 2013 | 09:15 PM
GaryLP's Avatar
GaryLP
Thanks for the advice, I have the original M/C lid, if it doesn't have a small vent hole it will have tomorrow.....
Old Jul 21, 2013 | 09:32 PM
montana_highboy
a 1/8th hole drilled in the lid will serve the same function....
The gasket, or rubber diaphragm if you will, acts as a "bellows", it's meant to expand and contract, without a lid vent there's a vacuum created inside the reservoir and it pushes fluid out under the lid gasket.
jhaas63
16
Oct 10, 2012 04:20 PM
dentside79
Apr 6, 2009 05:46 PM
sedly
Dec 23, 2007 07:46 PM
Beast12
Jun 5, 2005 12:13 AM
wa68ranger
Jan 9, 2002 02:48 PM
