1962 f700 specs
Post your VIN and the info from the warranty or data plate on the drivers door, or in the glove box or elsewhere in the cab. It will have transmission and axle codes along with GVWR info.
Tune up specs will vary slightly by engine type. You may have a Lincoln derived Y block....lucky you.
Post 7 here has tune up specs for a 368. I suspect these will work for any Lincoln Y block, as they are similar to SBF and FE specs--a Ford V8 with points being, after all, a Ford V8 with points:
Lincoln y-block 368 specs needed - help !!! - THE H.A.M.B.
Brakes--hydraulic? You will have a small master on the firewall with a hydravac on the frame under the driver seat. Actual brake size depends on the axles. Wheel cylinders tend to leak. Linings and drums are tough to find.
s/n- C70NU291571
?- 175 J C702 J G3
GVWR- 23000, HP- 163, RPM- 3600, ?- 720700
I couldn't make out what some of the numbers were for so I put a ?.
The air cleaner says it is a 302 cu in 180 hp.
Thank you. Appreciate all your help.
What kind of truck is this--flat bed, dump etc? Do you have plans for it?
C70 = C700 (C Series Tilt Cab).
N = 302 4V (Lincoln derived Y block).
U = Louisville KY Assembly Plant.
291571 = 1962, assembled May 1962.
175" Wheelbase.
J = Rangoon Red.
C702 = C700 Tilt Cab, 23,000 lbs. GVWR
J = Clark model 250V or New Process model N5A or N5B 5 Speed Direct.
G3 = Eaton model 16802 Two Speed Rear Axle / 6.50/9.04 / 18,000 lbs. Rear Axle Capacity.
23,000 lbs. Gross Vehicle Weight Rating.
163 net HP @ 3,600 RPM
720700:
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
0700 = Domestic Special Order number. The truck was special ordered by original purchaser, not "bought off the lot."
> > V8 Points/Condenser/Rotor/Cap same: 1958/73 FoMoCo Passenger Cars/Trucks ~ 1966/73 Bronco ~ 1969/73 Econoline ~ All 1974/75's without DuraSpark electronic ignition. < <
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Can is reverse rotation gear drive, if what I saw while looking for things is right.
These guys are talking the mostly extinct language of the Lincoln Y:
http://www.jalopyjournal.com/forum/s...d.php?t=693164
As for the tune up specs in my prior post, they can't be far off. Timing, not shown, is probably around 6 degrees, and you can fiddle with that.
You may fiddle with the point gap to get the easiest starting as well.
Another reference:
http://www.bangshift.com/assets/imag...g%20orders.png
tuneup.htm
