Sponsored by: Real Truck
Loosing MPG?
Old Jul 18, 2013 | 04:00 PM
woody367's Avatar
woody367
Loosing MPG?
I have a 04 F250 with the 5.4 and 65k miles. The computer ised to say 9.7 mpg bow over the last 5 mounths it reads 7.2mpg. I have reset the computer but never figured it out on paper, what might vause the change?
Old Jul 18, 2013 | 05:03 PM
redford's Avatar
redford
FTE Leadership Emeritus
The computer readout is anything but accurate. Calculate your mileage by hand.
Old Jul 18, 2013 | 05:05 PM
jakgod3's Avatar
jakgod3
Yes dont count on your lie-o-meter, calculate it by hand and see if your mileage is normal or not.
Old Jul 18, 2013 | 05:15 PM
redford's Avatar
redford
But, to answer your original question, there are dozens of causes for a decline in fuel mileage.
Weak COP
Worn out spark plugs
Dirty MAF
Malfunctioning IAC
Dirty air filter
Catalytic converter getting clogged
PCV valve bad
Slipping transmission
Suspension lift
Tires with more rolling resistance
Tires not inflated properly
Front end alignment
Front 4 wheel drive hubs locked
Axle bearings worn
Gasoline with more alcohol
Larger tires
More junk in bed of truck
More junk in cab
Passenger weight gain
Weather
To name a few anyway,
Old Jul 18, 2013 | 11:05 PM
BigOl04's Avatar
BigOl04
Weak COP
Dirty MAF
Malfunctioning IAC
Dirty air filter
PCV valve bad
Suspension lift
Front end alignment
Axle bearings worn
Larger tires
More junk in cab
Weather
and thats why mine is down
Old Jul 19, 2013 | 08:50 AM
phillips91's Avatar
phillips91
Good post Stuart lol. I saw a 2 mpg drop in mine at 40,000 miles. Turns out it was 2 bad coils and a bad plug. I calculate mine by hand on every tank and wouldn't trust the electronic one either.
philllog
Jul 30, 2020 07:40 AM
Iversen-fords
General Automotive Discussion
Feb 15, 2009 12:16 PM
bigdavesohc
1983 - 2012 Ranger & B-Series
45
Apr 1, 2007 09:49 PM
gitane59
Modular V10 (6.8l)
Jul 9, 2005 04:25 PM
1997FordF150XLT
1997 - 2003 F150
Dec 28, 2002 06:13 PM
