Bed Bushings???
Old Jul 18, 2013 | 08:00 AM
gangstakr's Avatar
gangstakr
Bed Bushings???
What are you guy's/ Gal's using for bushings? The rubber pad or block wood?
This would be what is between the bed and frame. Where did you get them and who carries these?
Old Jul 18, 2013 | 08:22 AM
schoo's Avatar
schoo
Used wood at the crossmember (oak that I made)
Used rubber cut to fit at front and rear 1/8"got it at Napa
Painted the wood black
Roy
Old Jul 18, 2013 | 08:40 AM
schoo's Avatar
schoo
NPD has them page 202 also I think mar-k has them
What bed is this 8'
Old Jul 18, 2013 | 10:04 AM
gangstakr's Avatar
gangstakr
What bed is this 8'
Yeah this is for a long bed 8' bed
Old Jul 18, 2013 | 10:21 AM
schoo's Avatar
schoo
2wd has the hump over the axle so blocks are shorter at that point
Little screws hold the blocks to crossmember
I glued the rubber at the supports
Old Jul 18, 2013 | 10:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by gangstakr
Yeah this is for a Styleside 8' bed.
schoo's F250 is a Flareside. Ford used wood blocks, but I wouldn't recommend using wood, as it absorbs moisture that is transmitted to the bed and cross members.
Won't be long before these parts begin to rust. Not pleasant!
Old Jul 18, 2013 | 12:30 PM
Jdeshler's Avatar
Jdeshler
Ford used wooden blocks? That is interesting
Old Jul 18, 2013 | 04:22 PM
dman2008's Avatar
dman2008
Ok so I used hockey pucks and just cut them to the desired height as required with a sawsall, worked really good IMHO.
D
Old Jul 18, 2013 | 07:29 PM
garbz2's Avatar
garbz2
Robert,
The bed had no rubber between it and the frame. Nor did the style side use wood blocks. The cross members are stamped and formed in a u shape with a mounting plate and oval steel gusset for the bolt to pass through
Flair sides had wood inserts.
Unis had a combination of wood and thin reinforced rubber.
Garbz
Old Jul 18, 2013 | 07:35 PM
schoo's Avatar
schoo
grabz what did the wrong bed have?
Old Jul 18, 2013 | 07:57 PM
garbz2's Avatar
garbz2
Wrong bed had nothing. Same as a 64 66 styleside. Metal on Metal.
But the lines worked for crap so it did not really matter.
Garbz
mj100
Sep 8, 2018 06:51 PM
Aftrmidnite
2015 - 2020 F150
May 12, 2018 02:25 PM
Grgrcr88
2009 - 2014 F150
Dec 1, 2017 07:41 PM
Ken2600
Jul 17, 2008 02:02 PM
