Front suspension component question...
Old Jul 17, 2013 | 04:21 PM
Romanova's Avatar
Romanova
While doing my first oil change on my new-to-me Excursion, I noticed this. The part (large pin of sorts) is protruding out. It is like this on both sides.
Is it supposed to be like this? This is on a 04 V10 2WD Limited BTW...
Thanks!
Old Jul 17, 2013 | 06:08 PM
DSN46's Avatar
DSN46
Mine has them also. They are supposed to be there. No worries
James
Old Jul 17, 2013 | 08:19 PM
Archion's Avatar
Archion
Veteran: Marine Corps
It's probably something they used on the assembly line. Like the pins and bosses on engine blocks and the vertical pins coming out of the frame on the obs trucks.
Old Jul 17, 2013 | 09:27 PM
Romanova's Avatar
Romanova
Was curious because there is a hole on the other side of the frame piece, yet I can't see that they are holding anything together. As long as all is normal!
Thanks all!
Old Jul 17, 2013 | 10:07 PM
EXv10's Avatar
EXv10
It is probably used for a hold down anchor when transporting.
Old Jul 18, 2013 | 09:56 AM
az_r2d1's Avatar
az_r2d1
It's normal. My 2wd v10 has the same pins sticking out.
Old Jul 18, 2013 | 11:33 AM
RobRoss's Avatar
RobRoss
That's where you put the factory jack, it's a lift point. There is a pic in the owners manual.
Old Jul 18, 2013 | 12:31 PM
X-Hibition's Avatar
X-Hibition
It shows the proper location for the front axle. Yours seems to be missing...
Old Jul 18, 2013 | 12:39 PM
supercrewjohn's Avatar
supercrewjohn
Yes its a factory lift point. I have a 2005 job2 version of your truck and its in the same place.
Hope you enjoy it!
I love mine, I just wish I could buy a 2013 with a 6.7 deisel. I have the v10 limited, with a 4.30, banks tuner, airraid intake, 285/70 BFG Load range E All terrains. 138K miles and have never had to do anything but normal maintenane. I do run Mobil 1 synthetic oil which seem to yield a little better MPG ( 0.1 or 0.2 MPG) and the trucks seems to idle smoother
FORD1954
Apr 27, 2016 09:25 AM
kr98664
Jan 12, 2016 02:11 PM
tazcliff
17
Feb 2, 2011 12:02 AM
carnut122
Apr 10, 2009 04:38 PM
blatherskite
Dec 14, 2004 11:19 AM
