My Dually gets updated
Old Jul 17, 2013 | 10:23 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Originally Posted by fordpride
You have to drill and tap
Look here:
https://www.ford-trucks.com/forums/1...r-install.html
Old Jul 17, 2013 | 12:00 PM
dieselsubmariner's Avatar
dieselsubmariner
My airstream is a 1959. But I just sold it so I can fix my truck . :-)
Interior mirror ? I still use it , to hang the beads from mardi gra :-)
Btw I like the conversion trucks but mine was just an xl when I started .vinyl seats and no extras
Old Jul 17, 2013 | 05:26 PM
427 fordman's Avatar
427 fordman
Nice looking truck! You'll like it even better with the new injectors.
Old Jul 17, 2013 | 05:56 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Wow that was an old Airstream, its interesting, how long did you own it?.
Interior mirror: LOL. The good news it that you have a big lateral mirrors
Old Jul 17, 2013 | 07:34 PM
dieselsubmariner
I had the airstream for a couple years, did a body off restoration with new frame and sold it empty , no interior ...
Yes I have big lateral mirrors , but if you look closely I also have large wide angle round mirrors just below it . Bought all four of them from a truck stop and got the mirror arms for free from a junk yard .
Thanks for the link for the gauges :-)
Old Jul 17, 2013 | 09:36 PM
dieselsubmariner
Quick question : could someone give me the length of the shift lever ? Floor to top of shifter . I'm gonna make my own since I can not find one local.
Old Jul 17, 2013 | 10:45 PM
FI460's Avatar
FI460
Right about 18-1/2"
Old Jul 18, 2013 | 06:41 AM
DIYMechanic's Avatar
DIYMechanic
For what it's worth the shifter doesn't have to be from a diesel. Even the F-150 shifter will work as long as it was a ZF and not the Mazda M5OD transmission.
Old Jul 18, 2013 | 06:56 AM
dieselsubmariner
I know , but for some reason there are none at a junkyard . I did however seen some nice baseball bats out of aluminum at Walmart that should fit just fine :-)
Old Jul 18, 2013 | 07:41 AM
DIYMechanic
I've always kind of liked the "wrench shifter" myself:
Old Jul 20, 2013 | 07:46 AM
dieselsubmariner
well, my old injectors are out,
new injectors are already here and i send the old ones, including my chip back to swamp to have the chip re-programmed for my truck (free of charge).
my new exhaust pipe came as well.. what a difference in size.
I did started taking the down pipe out and after a lot of cussing, 4 sawsaw blades and raising the left side of the cab, i got the #@!&% Downpipe out
Now to the turbo.. took the ebpv off, got the upper two bolts broke loose, but the lower bolts are tight. The passenger side did brake loose, but goes very hard and it seems like the stud is turning instead of the nut.. did not get the drive side lower nut off yet.. and yes i do have short trenches, s-bend wrenches, crows-foot.. I stopped yesterday and sprayed everything again with pb blaster.. lets see today. goal is to get the turbo out, and all the automatic stuff..
Old Jul 20, 2013 | 10:00 AM
Midwest Dually's Avatar
Midwest Dually
Any chance we can see about you getting to put a D-60 under that monster?
Old Jul 20, 2013 | 10:37 AM
  #28
dieselsubmariner
Dana 60 rear axle ? Why ? And if you supply it , I will put it in :-)
... Still working on that turbo . Finally got the exhaust flange bolts out , but the pedestal bolts are a different story . Done broke 2 swivel @$(@&$
Old Jul 20, 2013 | 12:46 PM
  #29
joshh's Avatar
joshh
hes talking bout a dana 60 front axle to make it 4x4
Old Jul 20, 2013 | 07:10 PM
  #30
dieselsubmariner
I do not think I will change to 4wd . I won't need it .
As for the progress I finally got the turbo out . Also remove the transmission and driveshaft today and replaced the u- joints on the manual driveshaft . I replaced the pilot bearing in my new flywheel as well . More tomorrow .
