VIN Tag Decode Help Please...
Old Jul 14, 2013 | 05:45 PM
xgkrx's Avatar
xgkrx
G' day F.T.E.'s,
Number Dummy are You there ???, if so could You help Me and Decode The Following VIN Tag for Me please,,, it is said to be A 1966 Ford F350 Factory Crew Cab Pick Up,,, Cheers and Best Regards Graeme...
F35YC846562 WARRANTY NUMBER<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
WB COLOR MODEL BODY TRANS AXLE<o></o>
132 8 F351 481 A 22<o></o>
MAXGVW CERT NET H.P. RPM DSO<o></o>
08000 172 4000 720849<o></o>
Old Jul 15, 2013 | 03:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by xgkrx
It is said to be: 1966 Ford F350 Factory Crew Cab Pickup.
VIN: F35YC846562 / W.B. 132 / COLOR: 8 / MODEL: F351 / BODY: 481 / TRANS: A / AXLE: 22 / MAX GVW LBS: 08000 / CERT NET HP: 172 / RPM: 4000 / DSO: 720849
Dunno if it was sold new as a pickup or not. 1961/68: There is no code within the VIN or stamped on the Warranty plate that defines...what type (if any) "back of cab equipment" these trucks came with.
F35 = F350.
Y = 352 2V
C = Oakville, Ontario Canada Truck Assembly Plant.
846562 = 1966, assembled April 1966.
132" Wheelbase.
8 = Springtime Yellow.
F350, 8,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
22 = Dana 70 Rear Axle / 4.88-1 / No Limited Slip / 7,400 lbs. Rear Axle Capacity.
8,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
720849:
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
0849: Domestic Special Order number, truck ordered special by original purchaser, not "bought off the lot."
There are no specific to Crew Cab ONLY parts listed in the 1964/72 Ford Truck Parts Catalog, NONE! It's like they never existed.
AFAIK .. all 'factory' Crew Cabs were assembled in Oakville thru 1979.<!--?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
Old Jul 15, 2013 | 06:24 AM
xgkrx's Avatar
xgkrx
G' day N.D.,
Thank You,,, I certainly appreciate Your continued help with My Queries-Questions,,, Cheers and Best Regards Graeme...
plum bob
18
May 31, 2018 12:06 PM
cammail
Feb 7, 2010 03:03 AM
66_in_ky
Jul 26, 2008 05:05 AM
headoncollision
16
Oct 13, 2004 12:00 PM
