Fuel tank vented ?
Old Jul 16, 2013 | 10:18 AM
fmtrvt's Avatar
fmtrvt
Originally Posted by bpounds
...... BTW, the photo you posted came from my website.
I know. I couldn't think of a better photo to use.
Old Jul 16, 2013 | 11:10 AM
bpounds's Avatar
bpounds
Here is a pic of the entire top of the tank. You can see the vent connection on each end. The hoses pulled off easily enough for me, and I stuck them right back on when reinstalling. I can't remember if there was a check valve on each end, or just the one shown in the other pic, but I'm thinking there were two. Either way, they are plumbed together. If a tank is holding pressure, I would suspect a problem with that check valve/vent.
Old Jul 16, 2013 | 12:36 PM
npccpartsman's Avatar
npccpartsman
The OP definitely said vacuum so I'd have to suspect that also.
Old Jul 16, 2013 | 12:55 PM
bpounds's Avatar
bpounds
I would suggest to the OP, leave your fuel cap loose until you get it figured out, so you don't starve the fuel pump.
Old Jul 16, 2013 | 01:08 PM
Per4mance's Avatar
Per4mance
Bill, I'm already ahead of you on leaving the cap loose until I can get back on my feet to start wrenching again. I found this by accident so i have a list that's getting a little behind,but i do appreciate the effort everyone is putting out to check on this for me. I will get to the bottom of this and let everyone know what was the issue. i am going to take the bed off to install a B+W hitch so it will make it alot easier to check out........Bill
Farmboypowerstroke
Feb 7, 2011 07:03 PM
chas4x4
Nov 4, 2009 06:43 PM
PaysonPSD
Mar 2, 2008 11:46 AM
muckypaws
1978 - 1996 Big Bronco
Aug 10, 2005 09:18 AM
