lpop issues
Old Jul 13, 2013 | 01:49 PM
ShellCaseyng's Avatar
ShellCaseyng
lpop issues
2000 7.3 powerstroke....should the pulley on the oil pump spin by hand if the belt is removed. having starting issue and there is oil on just about everything. not sure what happen but it cutt off while driving so i checked oil and dip stick was dry. never had oil stain under truck when truck was park so i was unaware of any oil leak. any suggestion on where to start diagnosing the problem'
Old Jul 13, 2013 | 05:06 PM
carltonwebb's Avatar
carltonwebb
What pulley are spinning by hand exactly? There is not a pulley for the oil pump per se. The low psi pump is run inside the crank pulley which is the lowest one(biggest too). If u turn that one by hand, you have major issues. The high psi pump is gear driven.
Start by putting oil in it and see where it comes from when cranking.
Old Jul 13, 2013 | 06:59 PM
BlueScab's Avatar
BlueScab
Check your Hpop lines.
Iron lhorse
1983 - 2012 Ranger & B-Series
Sep 25, 2016 07:02 PM
jkedward
Jun 30, 2015 12:06 PM
Vinford
Apr 17, 2009 02:47 AM
GeoffNJ
Oct 20, 2007 11:13 PM
jim henderson
Oil & Lubrication
Dec 23, 2002 12:29 PM
