HELP no start edge pulling eleven codes
Old Jul 13, 2013 | 08:53 PM
FUJINAMI1293's Avatar
FUJINAMI1293
cranks but doesn't start here are the codes im getting
P1280
p0472
p0198
p1119
p1690
p1000
p0475
p0640
p1105
p0683
p0670
just replaced the passenger side pig tail for the uvch pulled the whole engine wiring harness and made sure all was disconnected before doing so
any help would be great
thanks
Old Jul 13, 2013 | 09:13 PM
F350-6's Avatar
F350-6
Why did you disconnect the entire harness to just change a pigtail? Clear the codes and see what comes back. Did you by chance swap the connector for the IPR and EBP?
Old Jul 13, 2013 | 09:31 PM
FUJINAMI1293
forgot to plug in the 42 pin connector plugged it in disconnected and reconnected the batteries so now its not pulling the codes but weak batteries from cranking charging now will see what happens
dr67
6.7L Power Stroke Diesel
May 24, 2018 07:38 PM
Jetmech6
Nov 22, 2016 03:08 PM
CountryD
Oct 28, 2015 11:13 PM
iateatoad
13
Dec 8, 2012 10:35 PM
have3fords
Bronco II
Oct 25, 2007 02:30 PM
