Ford TBI
Old Jul 13, 2013 | 01:43 PM
DCrusher's Avatar
DCrusher
Ford TBI
What years did ford run a TBI on their engine this will give me around about year of the 351,trans and frontend is sitting under it.
Old Aug 9, 2013 | 09:59 AM
Conanski's Avatar
Conanski
None.. they went from carb straight to Tuned Port Injection.. on trucks anyway.
Old Aug 10, 2013 | 04:59 PM
DCrusher's Avatar
DCrusher
This is on a car engine came out of a old LTD police car don't know what year it is has to be before 88 it also has a serpentine belt system As you can tell its been setting outside this is what I plan on putting in a 55 Ford truck that I've started on along with the frontend The frontend is the main reason I started this thread to find out what year it is so I know what I have to work with unfortunatly I'm the one that took the body off of the frame and hauled it all the way from AL all the way to TX and gave the title to the junkyard to scrap the body in AL. now after years of sitting and finally getting to the 55 Ford truck I'm about to pull the cab off the frame and start my measuring for the frontend graphing.
Old Aug 10, 2013 | 09:44 PM
Conanski's Avatar
Conanski
I believe Ford only used that CFI(central fuel injection) on 302 crown vics between 1983 and 1985 and the 351 motors all got a carb of one type or another. Are you absolutely sure you have a 351? Unlike with the small block chevs these two Ford motors do not use the same block the 351 is physically larger with a much wider spread between cylinder heads. If the intake on the motor you have is only 8-9" wide that's a 302, the 351 intake is 11" wide.
Old Aug 11, 2013 | 03:53 PM
DCrusher's Avatar
DCrusher
WOW great info. I'll look into that in the next couple of days. THANX for the info that helps a lot.
nothercrash
Sep 16, 2010 10:37 PM
dave boley
Apr 13, 2008 08:42 AM
mrl390
Oct 23, 2006 01:43 PM
cactusbronco
General Automotive Discussion
13
Jan 5, 2005 06:42 PM
cac91
Oct 21, 2002 04:51 PM
