06 e350 van a/c HELP please!!!!
Old Jul 12, 2013 | 12:00 PM
Gixxkid1000's Avatar
Gixxkid1000
I'm new to this site I want to start off by saying hi and any help is greatly appreciated I have a 06 e350 van 5.4 liter and I'm having problems with the a/c I've already put every thing new compressor,condenser, dryer. And my low side pressure is suppose to be at 50ish area and it spikes up to 70. And the a/c also cuts off and throws it threw the top vents when speeding up and go's back to normal when letting of the gas. Any help would be appreciated. I already changed the check valve but it still losing vacuum on a acceleration
Old Jul 13, 2013 | 05:42 AM
JWA's Avatar
JWA
The change in air flow under acceleration definitely points to a vacuum leak somewhere---the check valve isn't your issue there.
I'd guess your leak is most likely centered around the vacuum reservoir or the hoses leading into or out of it.
Can't help with your system pressure diagnosis---we do have an A/C specific forum here that might be helpful. Cooling, Heating, Ventilation & A/C - Ford Truck Enthusiasts Forums
Yahiko
Apr 23, 2013 06:12 PM
rs4-380
Aug 17, 2012 10:16 AM
premiers x
Modular V10 (6.8l)
Feb 21, 2006 04:29 AM
windyhill
Jan 5, 2006 06:52 PM
