I have a 2005 Eddie Bauer 4X4 with the 6.0 and Automatic Temperature Control.
I need a new blower motor control module, and have been confused by what I have been able to find online. Can anyone provide the full Motorcraft part number, or other information so I can get one.
Are you sure it is bad? What are the symptoms if I may ask? If it not lit or in other words blank and fuse is good... weird trick, but I've heard and seen cycling the headlight switch on and off a few times remedies the issue in some cases. I don't know if it some kind of reset or just happenstance -and even I have a hard time understanding of what one has to do with the other -possible common relay or something. Worth a try.... about 4-5 times would you cycle switch
Post an update either way! I am curious to hear outcome....
