Rebuild question
Old Jul 11, 2013 | 10:06 PM
BigBodySage's Avatar
BigBodySage
Rebuild question
I've got a 92 f250 xlt 4x4 351w. Eventually I want to completely rebuild it. I was wondering if it is possible to completely get rid of all the electronic components of the engine. I'm talking about getting rid of the emissions junk, computer, etc. Basically how cars used to be in the 60s and 70s, no junk under the hood, just the engine. What would need to be done to make this possible?
Old Jul 11, 2013 | 10:23 PM
Evan_P's Avatar
Evan_P
A Carb swap? Cant have fuel injection without most of that "junk" under the hood. Yes you can do what you are asking.
Old Jul 12, 2013 | 02:57 AM
RandR10's Avatar
RandR10
You would want to get a carbureted intake manifold, which are pretty easy to come by for the 351. You probably have to switch out the ignition system. I don't think that distributor will work without a computer. Since it's a small block, any small block (maybe more?) dizzy from the 60s on up will drop in there, it's just a matter of deciding if you want points (60s) or electronic ignition (70s on up).
If you wanted to go really cheap and do electronic ignition without the computer, a couple companies sell retrofit kits that put an electronic pickup in place of the points on the older distributors. The points dizzys are really easy to come by and they're cheap.
Deleting the converters from your exhaust would be easy enough too. Just cut them out and weld in a length of pipe.
Doing those three things will return your truck to the pre-smog era. I think you might have an electronically controlled transmission too if your truck is automatic, so that would need to be swapped out as well. If you've got a 5-speed, you're fine. Most states have restrictions on what pollution equipment you need, even with older trucks, so check that out before you start tearing out your smog pump and cats.
If you want to go performance, there's lots of aftermarket support for that motor. Depending on how much money you want to spend, you can get 400+ HP out of it in semi-streetable form.
Regardless, unless you want to spend the big bucks and buy a crate motor, you should buy some books on SBF engine building and do some reading. Even if you end up going with the crate motor, you'll be better able to make your selection once you've done the proper research.
Old Jul 12, 2013 | 08:25 AM
Conanski's Avatar
Conanski
Yes this is possible but if your truck has an auto trans then it is also controlled by the engine computer so this conversion would involve replacing the transmission as well.
Old Jul 12, 2013 | 09:01 AM
raystankewitz's Avatar
raystankewitz
My 0.02 USD worth . . .
I take it your state doesn't do smog? Not yet, anyway.
Besides carbing the truck, taking out the high pressure injection pump(s) and swapping out the dizzy, you might have to do a possible trans swap if it's an automatic-equipped truck.
Regardless, eventually the entire USA will have the very restrictive Kalifornistan-type smog emissions testing. It might take a while, but everyone always looks to the west coast for inspiration. When that happens, you'll either have to convert the truck back to its former state (read; big $$$) or scrap it.
Ya know, even an old fart like me can appreciate the nicety of just turning the key on a cold morning and have my truck come to life and being able to drive off without all of the drama of fiddling with the choke, multiple restarts and poor cold motor driveability.
If I were going to go through the engine compartment of my truck, I would just neaten it up, swap polished stainless tubing for the plastic vacuum lines, re-route the lines to make them look neater, stuff like that.
But, each to his own. Just my 0.02 USD worth. YMMV.
Ray
GammaDriver
Engine Swaps
Mar 19, 2022 11:30 AM
86trouble
25
Apr 10, 2014 06:34 PM
86ford302
Dec 18, 2009 06:53 PM
'78 Custom
Nov 5, 2005 11:16 AM
nitro94
Oct 23, 2001 09:18 AM
