Engine/water pump question
Old Jul 11, 2013 | 09:27 PM
heykey4's Avatar
heykey4
For my '78 f150 (351m) I took the water pump off...it had gone bad.
Question: what's the metal plate behind the pump and where can I find a replacement as it is bent?
Old Jul 12, 2013 | 12:15 AM
tygerof2's Avatar
tygerof2
Plate is the timing cover plate. Not sure where to find one. Check LMC truck parts.
Old Jul 12, 2013 | 01:16 PM
Filthy Beast's Avatar
Filthy Beast
Straighten it out yourself. Been there. A nice, clean flat surface, a good beater and a vice will work wonders.
Unless, of course, the crank seal opening and oil pan gasket lip are pretzel-ised... Even then, depending on how bad it really is, it's do-able.
Old Jul 12, 2013 | 04:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which metal plate are you referring to?
The one that bolts to the back of the water pump (8508 in left lower pic) or the front engine cover plate (6B070)?
Old Jul 12, 2013 | 04:39 PM
heykey4's Avatar
heykey4
It's 6B070, no doubt about it.
kowen
Jun 5, 2019 11:52 AM
Tom Brown
Aug 30, 2017 05:47 PM
willowbilly3
Jul 1, 2012 11:28 AM
1947/67/77Ford
Sep 7, 2007 09:36 AM
