Overheating problems
Old Jul 11, 2013 | 06:31 AM
BKM-WR3's Avatar
BKM-WR3
Yesterday I was towing a load of gravel All of a sudden I noticed my ECT and EOT temps Climbing fast. I Then realized that I was not hearing the fan. I was not at a place where I could pull over so I had to drive another quarter-mile. My temperatures reached 230 both oil and coolant before I could stop the truck at a car wash. I have the CS insight to monitor these temperatures. I pulled the truck into a self-serve bay and with the motor running I sprayed water through the front radiators to get temperatures back down quickly. Two questions should I be worried about any damage from that hot temperature and what should I be looking at as far as the problem with the fan not coming home? When I was able to drop the trailer and get rid of the load my temperatures seem to go back to normal 192 to 198 with no more than a 4 degree difference between ECT & EOT. Outside temperature was 83. Thanks for your help.
Old Jul 11, 2013 | 09:11 AM
69cj's Avatar
69cj
Temp. wise I don't think you hurt anything with temps. of 230. You definitely need to find the problem. If you can monitor the temps. and shut her down if need be then try the trip home. You could be broke down in the middle of no-where trying it however. If you hit traffic you will be SOL without a fan. Check the connector to the fan before leaving. A known problem area. Good luck.
Old Jul 11, 2013 | 08:01 PM
BKM-WR3's Avatar
BKM-WR3
Thanks for the suggestion to look at the connecter. I will do that tomorrow. Is it something that is obvious or is it inside the connector?
Old Jul 11, 2013 | 08:16 PM
dlibson's Avatar
dlibson
Check the wires from connector down. Unplug it, and plug it in again.
Do you have any codes?
Old Jul 11, 2013 | 09:01 PM
BKM-WR3's Avatar
BKM-WR3
Yes I have two codes. PO480= Control Circuit Malfunction. & PO528= Speed Sensor Circuit No Signal. Are both of these codes fan related?
I should have thought to look for codes. Thanks
Old Jul 11, 2013 | 09:04 PM
dlibson's Avatar
dlibson
Yeah both fan codes.
Do you have an EGR delete? Is your valve plugged in? If it isn't, you need to plug it in.
If it is, you likely need a new clutch.
Old Jul 11, 2013 | 09:09 PM
BKM-WR3's Avatar
BKM-WR3
Truck is bone stock
Old Jul 11, 2013 | 09:11 PM
dlibson's Avatar
dlibson
Okay, well check the wires from the clutch. It will be the wiring or the clutch its self.
Old Jul 11, 2013 | 09:14 PM
BKM-WR3's Avatar
BKM-WR3
I will be looking at the fan clutch. Thanks for the help!!!
Old Jul 11, 2013 | 09:17 PM
BKM-WR3's Avatar
BKM-WR3
Is there a better option than going back with a OEM clutch?
Old Jul 11, 2013 | 09:19 PM
dlibson's Avatar
dlibson
No problem on the help.
Nothing better really. There are aftermarket options though that are often cheaper.
Old Jul 11, 2013 | 09:31 PM
BKM-WR3's Avatar
BKM-WR3
If it is the clutch I will go back OEM then.
Old Jul 12, 2013 | 05:52 AM
npccpartsman's Avatar
npccpartsman
If you do a lot of towing you might look into the snowplow fan clutch option. It's a little more heavy duty.
Redrockerstl55
Aug 3, 2018 09:50 PM
jmaskew
Jul 25, 2012 08:14 AM
1 Ton Tommy
Sep 2, 2009 11:32 AM
jlmotox
May 11, 2009 02:52 PM
PowerstrokeJunkie
28
Feb 5, 2008 10:39 AM
