1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Vacuum pump problem...AC defrost only?
Old 07-10-2013, 11:38 AM
ddiercks's Avatar
ddiercks
ddiercks is offline
Hi, hoping someone can help me out here. Its hot in St. Louis and my windshield sure is staying cold (ac blows from defrost vents only).
1999 Ford F350 7.3 diesel 4x4 (4x4 lever on the floor). About a month ago, the ac starts blowing out of the defrost vents only. I assumed it was a vacuum issue.
Lines looked good; very plyable still. Canister looked fine. The vacuum pump on the pass fender well smelled burnt, so I replaced it. Got the new pump in and it didn't work. Checked the fuse panel and found two blown fuses, replaced them and the pump worked.
Here's my issues: if AC max is used, the vacuum pump stops working and air blows through defrost only . If the dash switch is in the off position and then turned back on, air blows through defrost vents again and vacuum pump will not work.
Is there a solenoid or switch to this vacuum pump that I'm not seeing? Thanks for your help, Dave
Old 07-10-2013, 12:07 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Had the same problem about a week ago. Mine was just a fuse. But there is a vacum actuator below the glove box on the firewall. Just a guess.
Old 07-10-2013, 12:17 PM
senix's Avatar
senix
senix is offline
Received 1,428 Likes on 1,021 Posts
sometimes in 4x4 systems when you turn the switch it will go to defrost indicating a vacumn leak usually at the hubs.
Kind of don't think this applies in your case but worth a look.
Old 07-10-2013, 12:32 PM
ddiercks's Avatar
ddiercks
ddiercks is offline
Thanks guys. I'll need to take a closer look. I see a vacuum line leading down, but haven't seen a vacuum line near the hubs.
I keep reading different forums about this same issue, but it seems to only apply to trucks with the 4x4 switch on the dash, unlike my lever operated one.
Also wondering if the new vacuum pump is defective. When the pump stops working a little tap on the housing will turn it back on and then air blows from the vents...
Old 07-10-2013, 12:48 PM
senix's Avatar
senix
senix is offline
If you have a manual 4x4 then that is not your issue.
Old 07-10-2013, 01:09 PM
ddiercks's Avatar
ddiercks
ddiercks is offline
Senix, thats sort of what I was thinking. So, manual 4x4 means, no vacuum?
Old 07-10-2013, 01:20 PM
senix's Avatar
senix
senix is offline
No vacuum. Just the lever on the floor.
Old 07-10-2013, 09:09 PM
Firefighter 1406
The only way to go. IMHO.
Old 07-12-2013, 10:41 PM
ddiercks's Avatar
ddiercks
ddiercks is offline
Firefighter, thanks for letting me know about the actuater behind the glove box. That was the cause of my problems. There is a white vacuum line leading to that and a passenger must have kicked it off.
Plugged it back in and its been good so far (two days); all back to normal. Thanks again guys-Dave
Old 07-12-2013, 11:56 PM
Firefighter 1406
Sweet deal. Glad you got it fixed.
Old 07-13-2013, 06:00 AM
senix's Avatar
senix
senix is offline
Great outcome
Dude-Ford
34
01-10-2023 12:08 PM
plumbfishy
11-04-2010 07:21 AM
DGMFORD
17
01-07-2010 12:31 AM
dlevey
08-14-2004 11:10 PM
pat hand
07-14-2004 09:25 PM
Quick Reply: Vacuum pump problem...AC defrost only?
