overheating issue
Old Jul 10, 2013 | 08:04 AM
festusmo's Avatar
festusmo
overheating issue
Hello-I have a 1968 F-100 with a 360 V8 automatic. It runs hot. I installed a new fan shroud yesterday as it was missing the old one along with a new thermostat. Coolant is flowing fine-hoses are almost new and there are no leaks. What could be causing the running hot issue?
Old Jul 10, 2013 | 09:06 AM
elgemcdlf's Avatar
elgemcdlf
I would look at the fan location in the shroud. The blades should be centered in the shroud. In other words half in the shroud & half out. Are you running a fixed fan or a clutch type? Any play in the water pump shaft? It is a 45 yr old truck maybe time for a new radiator. Core support. Is it a big block core support or 6cyl? If a 6 cyl you will need to cut the opening out to match the radiator. I am assuming you have a big block radiator in it & not a 6 cyl.
What is "running hot"? All the time or only at speeds or idle? If at idle only it is related to air flow. If at speeds it is related to capacity. That is general.
Old Jul 10, 2013 | 09:17 AM
MIKES 68 F100's Avatar
MIKES 68 F100
Running hot or boiling over ?
if just hot what temp ?
boiling over can be as simple as a bad cap (beware of china made stant look alikes ) they are junk
Old Jul 10, 2013 | 11:30 AM
DeeV8er's Avatar
DeeV8er
Start with the lower cost items, temp sender, after market gauge and sender for testing. The radiator could have many tubes blocked and still allow coolant to flow but at a velocity that does not allow time for it to release heat.
Old Jul 10, 2013 | 01:28 PM
festusmo's Avatar
festusmo
Has a big block 8 cyl. runs just below 1st "hot" line at idle and when cruising after roughly 10 minutes. Blades are centered.
Old Jul 10, 2013 | 01:30 PM
festusmo's Avatar
festusmo
OVERHEATING ISSUE
Has a big block V8-running just below hot line at idle and crusing after roughly 10 minutes. Fan blades are centered. fan has no clutch.
Old Jul 10, 2013 | 02:02 PM
JEFFFAFA's Avatar
JEFFFAFA
Next time it is running that warm feel the grille side of the radiator core while idling. Top to bottom and all over. Where water is flowing it will feel hot. If it is partially plugged it will feel not as hot where water is not flowing.
Old Jul 10, 2013 | 03:18 PM
elgemcdlf's Avatar
elgemcdlf
I know the truck has a V8 I was talking about the radiator & core support.
Old Jul 10, 2013 | 03:31 PM
MIKES 68 F100
these old gauges are not accurate , get a new sending unit (like $9.99 ) see what temp is . if it hasn't changed then you need to start checking radiator for clogs , flush radiator/block . etc
Old Jul 13, 2013 | 05:44 PM
lee's Avatar
lee
Drain a few inches of fluid from the radiator so that you can see the core from where the filler cap sits.
See if the capillary holes are open or corroded/blocked with corrosion.
Lee
Old Jul 14, 2013 | 12:14 AM
orich's Avatar
orich
So, I assuming you've been driving this vehicle with no problems until now?
Or you just noticed where the temp is a little higher now that's it's summer, time verses your winter time driving.. Most radaitors slowly plug in the lower end of the core tubes and less at the top tank. Being that's where you can't see it. I'd say it's time to have your radaitor rodded out and maybe back flush your whole cooling system. The ole skool stuff that most people don't do or want to pay to have done any more. Also I'd install a manual gauge so you really know the temp. Check for lose belts, your's don't sound like it's running hot. But if your over filling your rad like most guys do until they learn or look for the (fill too Line) which is about 2" below the cap filler hole..
Coolent will get pushed out after the motor is shut off from heat expansion.. orich
Old Jul 14, 2013 | 05:31 AM
jowilker's Avatar
jowilker
festusmo Welcome to FTE & the Bumpside Forum.
Many guys come here comparing these 50 year old design to todays standards. Theses old trucks have a huge frontal opening and don't require a fan shroud. As long as the truck is moving forward 20 miles an hour it does not need a fan. The one thing they will not do is sit and idle and this is where the shroud & fan comes in. I have been around these trucks since they were new, my 66 has same basic setup as yours, it never has had a shroud, I did use a larger fan when I rebuilt the engine 12 years ago.
Are you loosing coolant?
John
Old Jul 14, 2013 | 10:24 AM
BobbyFord's Avatar
BobbyFord
Does it overheat in traffic, going down the highway, or both?
Old Jul 21, 2020 | 07:44 PM
Steve's Avatar
Steve
Air and water flow are critical for sure. If it runs normal temps at speed, then both air and water flow are at higher rates and that fits with normal operating temps.
The same is true of ignition timing. I don't know the details of your distributor advance mechanism(s), but if the engine isn't seeing at least some degree of static ignition advance in that 500-800 rpm zone, then this kind of hot running can occur. I have seen this on more than one occasion.
Does the distributor have centrifugal advance? Is it equipped with a Loadomatic vacuum advance? How is the distributor connected to vacuum?
Somebody more versed in this particular engine can tell you what a good initial advance is.
Old Jul 21, 2020 | 08:34 PM
orich's Avatar
orich
This thread is a few yes old if you have not noticed
