powdercoating vs paint
Old Jul 10, 2013 | 08:04 AM
ccllud's Avatar
ccllud
I just bought a ranch hand front end replacement bumper that came powder coated black. I have the red/tan excursion color combo and want to match it to the tan. I have been getting quotes of 400-700 to do this, which includes burning off the old powdercoat, sandblasting, and powdercoating tan. Thats way more than im willing to spend.
The current black coat is in good condition, and I heard you can paint ontop of powdercoat just fine. What do yall think about taking it to a painter and having them paint over the black powdercoat with a tan paint?
Old Jul 10, 2013 | 08:37 AM
ufvj217's Avatar
ufvj217
Id probably just paint it
Old Jul 10, 2013 | 08:51 AM
Apocalypse's Avatar
Apocalypse
Just rattle can it and see what you think. If it might be sandblasted anyway the paint will come off crazy easy and won't add to the price. Might as well give it a try.
Old Jul 10, 2013 | 09:20 AM
ithaca1230's Avatar
ithaca1230
I just went thru that the body shop I delt with told me they would paint over the powder coat but wouldnt warranty it so I got the new bumpers raw steel. He said it would work but eventually would start to peel. I would just paint over it.
Old Jul 10, 2013 | 11:39 AM
ccllud's Avatar
ccllud
Ok ill give it a shot. I for sure dont want it to stay black (black tan and red would look horrible I think). Im debating on either getting it done professionally or rattle canning it. Anyone have something painted like this and know how much it would cost roughly? (I got a 10ft long 5000lb smoker done for 400 in high temp paint so im hoping it would be pretty cheap)
Old Jul 10, 2013 | 12:28 PM
Apocalypse's Avatar
Apocalypse
I would ruff it up with some 60 grit, or better yet a wire wheel on an angle grinder. Follow that up with a good rustoleum (sp) primer at least 2 coats then the color of choice. Lowes has an insane amount of colors to choose from IMO.
Old Jul 10, 2013 | 01:15 PM
ccllud's Avatar
ccllud
would 60grit cut through the powdercoat? I read online that you shouldnt cut through the powder coat but rather just rough it up to help the paint stick
Old Jul 10, 2013 | 01:31 PM
Ilovemyex's Avatar
Ilovemyex
Paint sticks very well to powdercoat. In my experiences. You should be fine with painting over the powder.
Old Jul 10, 2013 | 02:55 PM
ithaca1230's Avatar
ithaca1230
I matched the bumpers to the trim color. Same as stock.
I think they look great.
Old Jul 10, 2013 | 03:25 PM
Apocalypse's Avatar
Apocalypse
I meant 60 grit by hand, if it's good powdercoat it shouldn't remove it.
Old Jul 10, 2013 | 04:49 PM
ccllud's Avatar
ccllud
Ill stop by home depot on the way home and then give it a shot on the back to see how it turns out
Old Jul 10, 2013 | 10:13 PM
Lance Helmert's Avatar
Lance Helmert
If you have a Carquest, they will be able to tell you what you need. They can mix paint to match either for a spray gun or put it in a rattle can. They can mix it for one coat gloss or base coat with clear gloss.
Old Jul 10, 2013 | 10:15 PM
EXv10's Avatar
EXv10
Powdercoat is great until it gets nicked up and then it's either spend a ton of time redoing it or paint over the nicks and crannies. note; I'm not an expert on it but that's how I see it. I have that problem with some Harley handlebars right now.
Old Jul 11, 2013 | 08:02 AM
Apocalypse's Avatar
Apocalypse
Honda forum I know, but it's good advice... [pics]Best way to strip powdercoating??? - Honda-Tech
Old Jul 11, 2013 | 08:17 AM
ccllud's Avatar
ccllud
I dont see anything on their website about custom colors. I will call them at lunch and ask.
As far as stripping it, i think I would be able to strip it with aircraft stripper pretty well, and I own a powerwasher which they said helps a ton.
