What are the torque specs for bell housing bolts on E4OD-7.3 liter diesel?
Old 11-26-2011, 09:41 PM
dixiegirlsc8's Avatar
dixiegirlsc8
dixiegirlsc8 is offline
Help please. How it almost done just need to know what the Torque is for the bolts.
Old 11-27-2011, 02:35 PM
Rongold's Avatar
Rongold
Rongold is offline
BOLT TORQUE
According to my 2003 shop manual, on the 7.3L diesel, the bolt torque is 45 foot pounds. For all other engines it is 35 foot pounds. They must use higher grade bolts on the 7.3 engine.
RON
Old 11-27-2011, 05:58 PM
spinella's Avatar
spinella
spinella is offline
i always thought it was a half of a turn before it snaps.....
Old 11-27-2011, 06:11 PM
dixiegirlsc8
Thanks so much Ron. That is what I thought just wanted to make sure. Transmission is done after several days of work and running great, except when put into gear there still seems to be a whining kind of sound in the torque converter. Is this normal for this truck?
Old 11-27-2011, 06:12 PM
dixiegirlsc8
lol thanks so much.
Old 11-27-2011, 06:15 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
What are you working on that has the E4OD behind it?
Old 11-27-2011, 06:58 PM
dixiegirlsc8
1994 F-250 7.3 IDI. is that what you are asking me?
Old 11-27-2011, 08:02 PM
F350-6's Avatar
F350-6
F350-6 is offline
He's the nosy type.
That and he'll move this thread down to the 7.3 IDI section so you get more views from the folks who have the same truck as you.
I've always driven a handshaker, so I can't help with torque converter noises. Good luck.
Old 11-27-2011, 08:04 PM
powerstroke72
Yeah 10-4.
The reason I ask is that this is posted in the Super Duty section and the Super Duty only had the 4R100 behind the 7.3 Powerstroke.
If you need more assistance with this, I can move it to the appropriate forum for you.
Originally Posted by F350-6
He's the nosy type.
Am I really that obvious?
ON EDIT: Chris is correct once again.....and as usual.
Thread moved to the Pre-Power Stroke Diesel (7.3L IDI & 6.9L) forum.
Old 11-27-2011, 09:39 PM
typefour's Avatar
typefour
typefour is offline
Bolts for the trans to engine? They are 95 ft lbs. 1/2 inch bolts will fall out at 45 lbs.
Old 07-10-2013, 11:49 AM
Rentaro's Avatar
Rentaro
Rentaro is offline
Just so everyone knows, my manual says 50ft pounds for the 7.5L and 65ft pounds for the 7.3 diesel
and for the torque converter bolts it said 34ft lbs
1989FordF250
10-15-2017 10:11 PM
jle70
11-14-2009 02:06 PM
rlc
02-02-2003 07:25 PM
Quick Reply: What are the torque specs for bell housing bolts on E4OD-7.3 liter diesel?
