cooling system woes
Old Jul 16, 2013 | 01:01 AM
tygerof2's Avatar
tygerof2
checking impellar clearance can be checked with a piece of glass laid on top and use a feeler gage for reference
Okay, so you mean when I take off the pump, check the clearance with your method? Not really any way to check it with pump in place, I guess. I've got a Robertshaw T-stat on order. the 333-180 version everyone suggests using. Hope that makes a difference. I'll keep updating to let you know the status. Thanks for the suggestions.
Old Sep 1, 2013 | 03:35 PM
tygerof2's Avatar
tygerof2
Update on my cooling system woes: I put a new Flowkooler water pump in with hopes it might help my situation. No better. Finally, found a post from SteveT and he had the exact same thing going on. I thought I was very thorough when I put the head gaskets on facing them both "FRONT". Well, after pulling both heads and checking, one of the gaskets was facing the wrong direction. So, yesterday I got it all back up and running. Problem solved- my own lack of attention caused the whole thing. Lesson learned. Anyways, for anyone else after me, MAKE SURE THE GASKETS ARE FACING FRONT-BOTH OF THEM!
Old Sep 1, 2013 | 08:00 PM
crsmiffy's Avatar
crsmiffy
glad it wasnt something terminal. Tim Meyers facebook site shows a good picture of head gaskets, indicating a visible tab if the gasket is around the right way. Very handy AFTER you have to pull your gaskets to check LOL
Old Sep 2, 2013 | 09:35 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Great info to know. I'm sure you have put in way too many hours and $$$ trying to solve the overheating problem. Maybe someone will avoid your headache with this post!
Old Sep 2, 2013 | 01:38 PM
tygerof2's Avatar
tygerof2
Thumbs up
I sure hope so. I thank everyone for their ideas and input. Its invaluable having the help on stuff like this.
Old Sep 2, 2013 | 02:37 PM
baddad457's Avatar
baddad457
It's a wonder it didn't do what I ran across in a 400 a few years ago. It too had a gasket on backwards, it never overheated (according to the gauge) but it would have a sudden explosion of pent up steam when the coolant that was blocked on that side of the block, & built up enough heat to flash to steam and backtrack it's way thru the pump into the radiator.
Old Sep 6, 2013 | 05:47 PM
tygerof2's Avatar
tygerof2
I think that is exactly what was happening to me too. It was making the thumping noise and it sounded like it was inside the pump, when in reality, it was doing what you described. I had several people who told me it "just needs to run for a while." I'm glad I didn't take their advice; I would probably be rebuilding the engine.My truck never overheated either. Glad I wasn't the only one to experience it.
Old Sep 9, 2013 | 08:29 AM
baddad457's Avatar
baddad457
That's exactly what the thumping was. With the coolant system design of the Cleveland (dry intake), if you put the head gasket on backwards, it completely blocks the coolant path back into the block to the T-Stat, so with it blocked it goes nowhere but builds heat til it flashes to steam (that's the thumping sound), then backtracks it's way thru the pump to the radiator and the cap that serves as the relief valve for the pent up pressure. With the other Ford engines, if you get the gasket on backwards, the coolant just shortcuts it's way back up to the T-Stat instead of circulating to the rear first, it'll still tend to over heat the coolant in the rear, but take longer to do it.
mikekp
1997 - 2003 F150
Mar 25, 2018 02:05 AM
firestorm21
1997 - 2003 F150
Aug 19, 2009 09:37 PM
dvmindy
13
Feb 16, 2006 09:07 PM
Wangman
Oct 16, 2004 04:26 AM
tatesomero
1983 - 2012 Ranger & B-Series
Jul 10, 2004 11:05 AM
