Squeaky, sticky clutch pedal
Old Jul 8, 2013 | 08:39 AM
INFOrd's Avatar
INFOrd
Unhappy Squeaky, sticky clutch pedal
Hi All,
My husband has a 1994 F150 single cab long bed 2wd with 5speed 4.9L I6. For a while, the clutch has been squeaking, but yesterday it actually stuck at the floor. After letting it all sit for a while, it seemed better. . . squeaky but not sticky. He asked me to check some forums to see if anyone was talking about a similar situation, but I can't find quite this scenario.
Thanks for insight and advice!
Old Jul 8, 2013 | 01:34 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Originally Posted by INFOrd
Hi All,
It sounds like the bushings are going out (Plastic) and need replacement.
A new kit is like $30?
Old Jul 8, 2013 | 01:41 PM
INFOrd's Avatar
INFOrd
Thank you! I'll pass it on. Hopefully that's all.
Old Apr 17, 2014 | 08:49 PM
Necromancer's Avatar
Necromancer
I have the same truck, same year. SideWinder, where can you get these bushings and how do you install them?
Thx.
NEC
Old Apr 18, 2014 | 01:54 AM
SideWinder4.9l
Thx.
NEC
The little clip on plastic bushing on the "Ball" of the clutch pedal rod is usually the culprit. $2-4 for it in the HELP! section.
The rest of the bushings are $36 from LMC Truck. If you look at the brake pedal assembly box in the catalog, you'll see the bushings listed as a kit.
Old Apr 18, 2014 | 06:35 AM
Diesel_Brad's Avatar
Diesel_Brad
It is called Lubricant
Old Apr 18, 2014 | 07:56 AM
Necromancer
i'll go grab them today. thank you!
Jesse73iditurbo
16
Mar 6, 2017 05:59 AM
timmyboy76
May 19, 2016 11:06 AM
JTyler11688
Jun 18, 2010 10:04 AM
brsexton
Aug 14, 2009 05:46 PM
WALT G
Jul 13, 2009 03:11 PM
